Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: How To: T50 Electronic Speed Sensor
    May 2006
    Default Re: How To: T50 Electronic Speed Sensor
    FYI - S53 ST185 and landcruiser speed sensors screw straight onto the factory speedo cable sender on a T50, W55, silvia box etc if you want a bolt on speed sensor.
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Quote Originally Posted by beerhead View Post
    This is the exact item i replaced with this new modified unit.
    This screw on unit works fine but I did not have the room in the transmission tunnel for it to fit on the original speedo drive and was runnig it off a 90 deg bend which just made it stick out the bottom of the car. Not happy with this the above is what I came up with.
    For the record the modified speedo drive is still working well without any dramas.
    asd
    deleted deleted
    Nov 2011
    Quote Originally Posted by djchye View Post
    How do you work out the pinouts on the sensor? I guess is 12v, GND, signal and I guess you can spin it over and measure between signal-12V and GND-12 but how would you tell which is the GND or 12V pin.
    Looking at the photos in the above post with the lugs at the centre facing to the top numbering 1-3 from the left
    1. 12V ignition
    2. Signal
    3. Ground
    An alternative more compact sender is this one..
    NEW Isuzu Amigo Rodeo Trooper Vehicle Speed Sensor VS | eBay
    And it's the same one that the likes of Snake racing sell for $120. Use these with some of the 1UZ into Surf conversions if you want to use the later electronic speedo and don't want to give Mr T your left nut to change the cable to the electronic sender
    I do have a couple of senders from the A340 trans left over from some conversions if anyone wants them
    asd
    Thanks 4th Surf.
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    Had a look at the above but needed more compact, ended up with a vdo one and relevant adapter key to suit.
    Sender Speed 340.808 vdo
    Junior Member Backyard Mechanic leso's Avatar
    firstly ...bazooka....great work there.
    i am lucky to have enough room for the one in the pic got mine from a mx83. i bought a pulse counter from jaycar and trialed it the other arvo works great counts 4 pulses per turn of the sender. i found the wires to be a bit arse about from what has been said. Positive is to one of the outside ones the centre one goes to earth and the other one goes to the pulse counter...that is what works for my counter . so when i am ready just drive it for a k and read what the counter says...
    cheers leso
    just found this in my favs...http://www.toymods.org.au/forums/tec...or-wiring.html
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. speed sensor plug on 92 st184 help?
    By toymotorsport in forum Tech and Conversions
    Last Post: 16-11-2007, 10:09 PM
