Results 16 to 18 of 18
Thread: What does the Water to Air I/C computer in a 1GGTE do / control
    Built not Bought Grease Monkey Rosie's Avatar
    Default Re: What does the Water to Air I/C computer in a 1GGTE do / control
    Still have not removed the fault, although the cars runs perfect now without fixing the fault - i have a spare ecu so i may try the random Resistance / earth/ volatge application to see if i can remove it.
    Looks like she'll be all engineered before christmas...........
    1977 RA28 1GGTE - never ending project
    Cough 'yaris' Cough - don't ask.
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    If the car runs fine, I would leave it at this point, if the code dissasembly goes well we will be able to work out what needs to clear any fault without the trail & error method or if indeed there is a fall back map.
    Also I have a couple of ECU, if you wanted to try these out & I can find out if they work ?
    Good luck with the engineering
    Manuel
    If you're not using a water/air computer, just dig up a Gen2 ECU. They're pin compatible, but won't throw a code
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. Emmission control computer
    By Invid in forum Tech and Conversions
    Last Post: 05-03-2006, 10:32 PM
