Results 1 to 15 of 20
Thread: 4age Maximum Revs
    Jan 2007
    Somerset (UK)
    Default 4age Maximum Revs
    I aplogise as I am sure this type of question is asked over and over again.
    I have an 4age AE92 engine used for rallying. It has a cam that is a bit too hairy but providing I can keep it up on the cam all is OK and the car works quite well and is successful in its class on UK forest events.
    The spec of the parts is:
    7 rib block with oil squirters
    Standard crank - 42mm big ends
    Wasser forged pistons.
    Standard rods
    ARP bolts and studs throughout
    Firdanza aluminium flywheel
    All fully balanced.
    The engine is dry sumped.
    This puts out a maximum of 190bhp at 8000rpm and has between 130 and 135 foot pounds of torque from about 5500rpm to 7400rpm.
    I currently have the rev limiter set to 8500rpm.
    What would be considered to be the maximum revs for this spec of engine?
    Would it be safe to go to 9000 which would make a difference on a cammy engine?
    4AGE in a RWD Peugeot 306 Rally Car
    www.306rwd.co.uk
    Default Re: 4age Maximum Revs
    when you talk about rev limits, above a certain point it there is no safe engine speed as such. ie, higher engine speed reduces the lifetime of rods and bolts.. the faster you spin it, the shorter(^2) the lifetime...
    the ARP bolts will help a lot, the 92 rods are the beefiest/heaviest, and heavy pistons (??) don't help the rods but..
    how long do your engines last at 8500? (edit: and can you afford to break one?)
    are you still gaining torque up that high? or it is already falling off?
    oregon
    valve springs... valve springs.... valve springs!!! You didn't mention anything about the valvetrain other then "hairy cams"
    frequently a valve spring failure leads quickly to other parts going booom.
    Jan 2007
    Somerset (UK)
    I have been revving these engines in different guises to 8500 in rally cars for years. I have blown 2 engines when I ran the bearings and this was definately down to oil surge problems which is now cured with the dry sump system,
    Unfortunately I have to rev it to keep it on the cam when changing gear.
    I have a dyno graph at this address HERE
    www.306rwd.co.uk
    Jan 2007
    Somerset (UK)
    Quote Originally Posted by oldeskewltoy
    I don't know the make of the valve springs but they have never caused a problem before at these revs. I also have one piece valves.
    www.306rwd.co.uk
    S.A
    I cant see any issues with pushing it to 9000. I push mine up there quite often and its not dry sumped. I havent had any issues as yet........ not to say there wont be any
    Im using pretty much the same bottom end.
    blacktop 20v excluded I thought the rod bolts where the weakest link in a 4ag engine? I hear they give you at around 9000rpm
    Jan 2007
    Somerset (UK)
    I guess steel rods would give me what I want, 9000 + a bit.
    Rod bolts are ARP so hopefully they will be OK. Although I have been told that the originals are just as good as ARP.
    www.306rwd.co.uk
    I have some cheap rods + arp bolts for sale but for 9000+ I dont sugest it
    well I am honest
    i recon... give it a go... pull sump off and check bolts for stretch periodically.. maybe pull rods out and get them NDT'd for cracks (they are already shot-peened?) and if you see something bad.. swap... if it fails.. well at least you know...
    Sep 2008
    4age's love it up in those rev ranges, i know it is different but don't those olmpic series motors rev to like 15000rpm
    err... atlantic.. and err.. limited to 10500rpm..
    and err.. light rods and pistons and low tension rings and light valves and everything else optimised for 10500rpm....
    err....
    perth
    haha @ err...
    oregon
    Atlantic engines are no longer Toyota... SOOOO many Atlantic builders are building WELL over the old 10,5 redline... some are reaching 14k!
    Junior Member Backyard Mechanic gixer's Avatar
    I put Crower rods in mine, not real cheap but now I don't have to worry about stock rods!
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  2. 4AGE -> AE86 Conversion: Accessories question
    Last Post: 17-06-2008, 08:53 PM
  3. 4AGE Camshaft Guide
    By ehendrikd in forum Tech and Conversions
    Last Post: 03-07-2006, 09:37 PM
  4. Replies: 10
    Last Post: 22-01-2006, 02:58 PM
  5. 4age keeps bouncing off 3-4 grand ???
    By orange86 in forum Tech and Conversions
    Last Post: 15-12-2005, 02:29 PM
