Results 1 to 10 of 10
Thread: 1UZ physical dimensions & autobox question
    Default 1UZ physical dimensions & autobox question
    Hi all, i've searched but couldn't find an answer.. Please point me in the direction if this already exists.
    Does anyone have the actual physical dimensions of a 1uz, height and width and length with an auto box hanging off it? Or length of just engine.
    Also, with the auto gearbox does that need linkages to the stick, or is it electric?
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Junior Member Grease Monkey nilprospects's Avatar
    Sep 2008
    Default Re: 1UZ physical dimensions & autobox question
    I'll measure the one i have on my stand after work tomorrow
    Sep 2008
    you're looking around 640mm wide (outermost part of heads) by 600 long (rear of block to front of crank)
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    For more info Joel,
    Head over to www.lextreme.com
    Good bunch of guys there, and plenty of information regarding these engines.
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
    Montrose
    What are you putting it in?
    Apr 2007
    From memory mine was like a cube as far as measurement roughly went, 700 x 700 x 700mm, for just the engine .. Auto is linkages ... The one great thing about the Auto is it is quite small in diamemter .. Fitted my Mazda tranny tunnel with ease ..
    It may find it's way into a Toyota Coaster.
    Thanks all for the measurements, that'll get us started to see if its possible.
    Currently a 22re sits there..
    Bugger about the linkages for the auto though. Was hoping there was some electronic shift boxes around as the stick is a long way from the box in the bus.
    Eltham vic
    the linkages can be replaced by morse cables
    they are quite strong and work well
    we used them in the jet sprint boats they never failed
    ian
    Penrith BC
    ../delete/ban
    tech moderator
    Ian, with the morse cables what actual shifter do you use?
    Thanks Ed, that picture speaks 1000 words.
  1. Checking / setting 1UZ Ignition Timing (noob question)
    By AndyTTR in forum Tech and Conversions
    Last Post: 02-03-2008, 11:40 PM
  2. 1UZ VVTI... Wiring questions.
    By MWP in forum Tech and Conversions
    Last Post: 07-06-2007, 04:00 PM
  3. 1UZ injector question
    By amichie in forum Tech and Conversions
    Last Post: 18-12-2006, 02:38 PM
  4. 1uz bellhousing dimensions..
    Last Post: 06-07-2006, 12:13 PM
  5. Help with SC12 dimensions.. + MAP question
    By aconnoll79 in forum Tech and Conversions
    Last Post: 26-05-2006, 09:02 PM
