Results 1 to 3 of 3
Thread: Checking / setting 1UZ Ignition Timing (noob question)
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Default Checking / setting 1UZ Ignition Timing (noob question)
    I'm going to change the caps and rotors in the Soarer this week and was wondering about checking / setting the ignition timing.
    I've done this heaps of times on the old celica, but the problem here is that this engine has 2 separate distributors - is there a special procedure for checking the base timing? Is it even adjustable or is it locked from the factory?
    Andy
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    Default Re: Checking / setting 1UZ Ignition Timing (noob question)
    You cant Andy
    It is all in the brain. (ecu)
    MATT.
    P.S. unless you are running aftermarket
    Wicked bad, cheers matt!
    PS. I saw ward had a manual conversion kit for a soarer on ebay... must... resist... temptation.
  1. 7mge brian crower cams and ignition timing issue
    By amichie in forum Tech and Conversions
    Last Post: 29-10-2007, 10:54 AM
  2. I need help setting the timing on my 4k. *sort of fixed*
    By Aust162 in forum Tech and Conversions
    Last Post: 03-05-2007, 03:33 PM
  3. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 06:52 PM
  4. Setting the Timing on a '90 Landcruiser
    By Yumbo in forum Tech and Conversions
    Last Post: 21-02-2006, 08:33 PM
  5. 7MGTE Ignition signal wiring question
    By 1200det in forum Tech and Conversions
    Last Post: 07-01-2006, 11:16 AM
