Results 16 to 20 of 20
Thread: 4age Maximum Revs
    Default Re: 4age Maximum Revs
    Quote Originally Posted by oldeskewltoy
    Atlantic engines are no longer Toyota... SOOOO many Atlantic builders are building WELL over the old 10,5 redline... some are reaching 14k!
    on the 4A or the new motors?
    how many minutes would you expect a 4A to last at 14000rpm?
    I am very far from being any expert but I dont see how any 4age engine could make max power above 11,000 considering the shape of the ports regardless of the cams.
    For a reasonable build I still suggest spool rods as they are a very well made rod, strong as and a fair bit lighter than even a spindley blacktop rod.
    I do not about anyone else but I'd be changing cam specs to get a longer fatter torque curve.
    Some good torque between about 5000 and 7500 rpm with max power at 7700 means it would be a lot less hairy and you can keep it in each gear longer.
    Then there is less issue with engine life.
    With the light flywheel the engine can still speed up and slow down quickly allowing good throttle balance and quick response.
    Regards
    Rodger
    oregon
    all I said were some were reaching 14k.... that was the question.... max revs...
    on the street... or even partial street... there is no need for an F/A engine.... Keep it under 9k and build as FAAAAT a torque curve as you can
    i thougth the question was... what is safe max revs for english forest rallying events
    an FA engine is not appropriate for rallying either..
    so you are saying that there is no problem going from 8500 to a 9000rpm rev limit on stock (92) rods and ARP bolts?
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  2. 4AGE -> AE86 Conversion: Accessories question
    Last Post: 17-06-2008, 08:53 PM
  3. 4AGE Camshaft Guide
    By ehendrikd in forum Tech and Conversions
    Last Post: 03-07-2006, 09:37 PM
  4. Replies: 10
    Last Post: 22-01-2006, 02:58 PM
  5. 4age keeps bouncing off 3-4 grand ???
    By orange86 in forum Tech and Conversions
    Last Post: 15-12-2005, 02:29 PM
