Results 46 to 49 of 49
Thread: R154 box noisy in gear? what has gone wrong?
  1. #46
    vic
    Default Re: R154 box noisy in gear? what has gone wrong?
    Wrong tailshaft angles can cause lots of NVH problems in cars.
    As can new tailshafts until the unis run in.
    Dave
  2. #47
    Tallahassee, FL USofA
    Quote Originally Posted by Cressid@
    put about 2mm spacers to lower the gearbox mount. Noise completely gone!!! :
    Metal to metal contact, trans hitting the tunnel?
  3. #48
    Mobile Backyard Mechanic PeteH's Avatar
    May 2007
    Quote Originally Posted by allencr
    I think this will have been the problem. With the box fouling the body it can get a little noisy inside.
    Cressid@ as your problem wasn't there originally and only started after towing I believe that your transmission mount may be on the way out. Perhaps the loads from towing have weakened the metal to rubber bonding allowing the box to twist more when it's under load. Spacing the crossmember down 2mm has given the box little more room to move, but the noise will probably return in time with a little more use. Check the box mount out and see if there is alot of play there.
    I have the same gearbox in my MX83 and even after heavily modding the tunnel with a 5lb lump hammer, and much swearing, I found that I still needed to space the crossmember 8mm off the body to provide adequate clearance.
    Peter
  4. #49
    Is awesome Backyard Mechanic
    Jan 2008
    that explains it, i think!
    Will replace the mount if the noise come back.
    I am just glad it wasnt the box, it is unique for my car!
    Quote Originally Posted by PeteH
    Peter
  1. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 08:00 PM
  2. R154? Good or no good?
    By TTV8RA23 in forum Tech and Conversions
    Last Post: 12-02-2008, 09:18 AM
  3. changing the gear ratio's in hilux diff.
  4. R154 gearbox rebuild gone wrong
    By Esselte in forum Tech and Conversions
    Last Post: 17-04-2006, 11:24 PM
