stuck in two gears maybe... try pushing the clutch in and see if it will wind over
hey guys
engine has just been rebuilt & has been driven for about 1000kms
i just put a new 2tc & gbox in the bat mobil i cant even turn it by hand
it makes a click & then wont turn any further
the gearstick wont move either & ive tried 2 gear sticks & nothing, even with the clutch in
ive only got today to work on it as ive got to study for my hsc from now on
thx heaps
Bat mobil + 4age.. Engine painted, Fitting up now. Not long...Originally Posted by roadkill
Live life on the edge.
but when i turn the engine by hand it makes a click & then wont turn any further
btw its just been rebuilt is that just the compression
so how so i get the gbox to work
thx
ok i used my grill to hold my clutch in & now i can turn the engine by hand fine
any ideas with the gbox & how do i fix it
thx heaps
it's rooted.
why woyuld you put in a gearbox that was rooted? didn't you check it before you put it in?
why did you swap out the gearbox that had been used with the engine for 1000km?
why do your threads make no sense?
maybe you should stop worrying abotu cars and study for your HSC.
pull the shifter out and move all the shift plates around with a screw driver so that they line up properly, then put the shifter back in and all will be sweet. As said above it is probably engaging more than one gear. Just have a fiddle and you should find the right spot for the shifter, thats what i did anyway.
Catchya, Josh
'74 TA 22- 2tg with massive cams!
"Full carpeting, tinted glass, a tachometer and a Rally-style electric clock."
Originally Posted by oldcorollas
thx heaps, what is the problem & how can i fix it
ive got another 2 t50 but i really dont want to have to swap it out & put another one in right now
Forget the POS and study for your HSC mate.
all fixed, thx heapsOriginally Posted by 74canbra
Welcome to ToymodsOriginally Posted by oldcorollas
It’s great to have you!
ToyMods provides a friendly environment for Toyota owners and enthusiasts in which they can learn how to modify their car and improve their automotive skills.
and maybe YOU should read the clubs credo a little more carefully
I dont know if you had a bad day, but that is no excuse to unload on someone for simply asking a question.
I cant say I had any trouble making out what Cob was getting at....
I think someone is about the get the neg repping of their lives![]()
its only rep.... meh
Hi, thanks for having me, glad you can copy and pasteOriginally Posted by wa5
I take it you have experienced Cobs last few threads that went forever and round in circles due to BASIC things not being checked?
I also assume wa5, that you got another PM from the OP asking you to help on these basic things?
what? you mean people don't PM you all the time asking you to help in threads? you should try it sometime
i wrote
it's rooted... = there is something wrong.Originally Posted by oldcorollas
it's rooted.
if you read the first post, he says the engine has done 1000km, and now he has put in new gearbox (and engine??) and now there is a problem.
that means, in a freekin nutshell, that either the gearbox is fucked, or that he didn7t install it correctly.
going by the past marathon threads, i would assume that he either didn't check the gearbox before it went in, and it is fucked, or he installed it incorrectly.
to give him the BENEFIT OF THE DOUBT, i asked if he checked the box before he put it in..
i asked why he swapped out the previous(1000km) gearbox.
sure the "threads make no sense" is a cheapshot... but the original post does not make much sense
and YES, he SHOULD BE STUDYING FOR HSC instead of fucking abotu with cars, trying to make the do wheelstands, and installing things incorrectly. i think, for him, studying for the HSC will give him much more benefit for the rest of his life than having a gearbox that works.....
IN THE END, i shouldn't have given him the benefit of my doubt, and i should have just told him it was installed incorrectly.... which was the case.....
as for gearbox, a gearbox, unless it is A) BROKEN, or B) INSTALLED INCORRECTLY, ..... CANNOT be in two gears at once. there is no physical way, unless the lockout pins/spring have been removed or the spring is borked, OR, he installed the shifter incorrectly...
gee![]()
i only posted because he ASKED ME FOR HELP again.....
edir: what is the point of neg repping someone on a high horse![]()
oldcorollas- To know when to be generous and when firm—that is wisdom.
Thx
