The first things to check is that its definitely in park....or see if it can possibly start in neutral. since its auto, if the starter throw out gear is old ar faulty it may not be engaging on the flywheel you may need to crank the engine a little by hand. This will rotate the flywheel a little bit and hopefully the teeth will mesh in.
Another thing to also check is that the battery has enough kick and the wiring from the battery to the starter is intact.
If all that yields no joy, then maybe the switch thats on the shifter mechanism is at fault.
