Results 16 to 30 of 34
Thread: pwr steering on mx83 1jz
    Default Re: pwr steering on mx83 1jz
    When I got my car it had the JZX81 rack and PS pump, steering was quite heavy as I didn't have the solenoid hooked up.
    Hooked it up to 12V and it was WAY too light, could turn the wheel with no effort at all.
    Sourced a Crown (UZS131??) PS computer and hooked it up to the speed signal and rack, now I have speed sensitive power steering in my MX83/JZX83
    244rwkw / 328hp @ 18psi
    CAE86 Grease Monkey ae95's Avatar
    will see if my gx81 has one
    and take some pics if it does
    thread revival
    Where is this solenoid located in a jzx81? I have a jzx81 rack and the steering is heavy so I suspect that it hasn't been wired up.
    Also,
    anyone know if the rack mount bushes are the same between mx83 and jzx81 as I need some and wondering if I can get Cressi ones. And what is involved in the process of a steering rack recondition? Would they do this?
    Thanks
    Chris
    QUICKEST 1JZ'S IN OZ
    to reco the rack they replace the seals in the 'input shaft' (i think its called) and replace the rod ends and rubber boot things.
    i had to get mine done because it was leaking all over the place. i dunno how hard it is but at pedders they have a cut away model of a rack and it doesnt look that hard to do by yourself.
    when i did a conversion for someone (1JZX83) i just powered the solenoid on the rack from an IGN source.
    thats the "hard" setting but its perfect
    Old post I know, but its the opposite way around.
    12v = uber light
    unplugged = heavy.
    They charge $600 to reco a rack.
    The 'seal kit' cost $30.
    That should show you how labour intensive it is.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    The solenoid is in the valve body of the steering. Should be a 2 wire plug coming out of it, near where the steering shaft comes down. I have mine disconnected and love it. Much better than loose as steering.
    Rack reco they disassemble completely, replace the internal seals on the rack (what leaks when fluid is coming out of the boots), new seals in the valve body, new bearings on the pinion, set the preload on the pinion bearings and the rack guide, new rack ends and new rack boots.
    Not overly hard, definitely not east. You need the correct tools, and the manual to know how to set preload etc. For the price the kit would be with the rack ends, bearings etc, I'd be getting a reco rack.
    They don't supply new rack bushes. Not sure if JZX81 and MX83 ones are the same.
    Jun 2006
    Tasmania
    i have a pot wired into my progressive power steering replacing the speed control box. Means i can change it with the turn of a nob
    I can't find this solenoid hey! Anyone got a pic?
    http://www.toyodiy.com/parts/p_G_198...PGFQ_4505.html
    Big solenoid looking thing hanging off the rack.
    Maybe not all JZX81's had it, or maybe you have a GX81 rack which may not have it.
    thanks a lot Will check it out again tomorrow. Definitely jzx81 as the whole crossmember and everything was taken from front cut and bolted to cressida
    found it Fixed the rubber bushes though and it feels good now. It definitely isn't plugged in but I think I will leave it as is anyway. May try it out at some stage I guess?
    Jun 2006
    Tasmania
    dont leave it unplugged youll stuff it in no time, especially if you drifting
    why? and no drifting for me
    Its a regulator, its designed to be run at both extents, i see no reason why it would stuff anything up.
  1. 1jz in mx83
    By mojo_type in forum Tech and Conversions
    Last Post: 28-06-2011, 07:59 PM
