Results 1 to 7 of 7
Thread: 1UZ-FE into RN90 HILUX 2WD
    Jan 2008
    queensland
    Default 1UZ-FE into RN90 HILUX 2WD
    Hi all,i'm fairly new to this but i can't find anywhere that advises on the best sump for this conversion, to my knowledge there is front,mid and rear sumps. I have been told by someone who's done a 1JZ install that the rear sump is the way to go but looking at the chassis and where the sway bar sits it looks to me that front is better. Front sump engines are a lot more common than rear sumps in Brisbane anyway so another thing i wondered is there anyone out there with a rear sump and pick-up that wants a front, I havent bought the half-cut yet but have got my eye on two Celsior cuts. Any advice on anything involved in this conversion would be greatly appreciated, I'am also doin the BA FALC/R33caliper front brake upgrade and have collected all the necessary hardware so will be done very soon. THANX in advance.
    Jul 2008
    Default Re: 1UZ-FE into RN90 HILUX 2WD
    hi Mick, I have just done this in my 98 2wd work mate and i used the front sump.i still had to cut the back of the sump to clear the steering.i ended up making a new steel section.I am in Maryborough QLD . if you need any more info just ask.
    Cheers, Alan
    Forum Sponsor Conversion King
    the easiest sump for the job is a UZZ3# series sump (soarer),
    they are a rear sump and wont need to be cut to get around the draglink,
    the only drama you may have is with the factory swaybar but its fairly common to just space them down accordingly.
    linden
    SPANNER CRAB Grease Monkey AE3SGTE's Avatar
    Jul 2007
    Done this exact swap twice now, and used front sump Celsior or Crown motor.
    Pictures
    http://www.toymods.net/forums/showth...hlight=AE3SGTE
    With CRS engine mounts the "drag link" or "steering arm" does foul on the sump, but only just. With 19" wheels on you can't turn lock to lock anyway.
    You will need to make up spacers to go under the sway bar mounts.
    And the handbrake cable housing just touches on the head cover, but there is another model hilux that has the housing on the inside of the cab, straight swap.
    All minor little things
    Apr 2007
    No biggy, but you will find the crown motor's are mid sump ...
    Jan 2008
    queensland
    1998 to 2005 2wd and 4wd had the handbrake cable mounted on the inside
    Jan 2008
    queensland
    Thanx for the info mate,i actually got mine from a 4runner and worked out the hard way that the lefthand side footrest mounts are not screws with a funky cap on them they're actually these long single use plug things that don't like to come out so anyone cruisin wrecking yards for such a setup should be aware that the thin steel bracket that holds it to the floor is easier to break off donor vehicle than get them dam things out, and if you do work them out they'll be rooted anyway,Toyota does sell them as genuine parts{not cheap}. You do need the footrest though as the cable is held in place by it just before it goes thru the floor. Hope this helps someone.
  1. Conversion Trouble 1UZ into Hilux?
    By boshy in forum Tech and Conversions
    Last Post: 13-07-2009, 09:46 PM
  2. quadcam 1uz into a 91 hilux
    By aristo_newy in forum Tech and Conversions
    Last Post: 28-09-2008, 07:13 AM
  3. Hilux - BA Rotors - Nissan GT Calipers
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 20-02-2008, 07:27 PM
  4. Help Needed - Auto Electrical RN90 Hilux
    By MrBags in forum Tech and Conversions
    Last Post: 29-10-2007, 12:09 AM
  5. Hilux Tow Bars and Wheels
    By Son of Toyoda in forum Tech and Conversions
    Last Post: 26-06-2007, 06:09 AM
