Results 1 to 15 of 16
Thread: oxygen sensor wiring
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    Default oxygen sensor wiring
    just about to go wire up my four wire oxygen sensor, (as my car is only a single wire)
    reason being, my sensor has been moved to the s2 postion, and needs a heater to work effectivly now,
    Stock Toyota 4 wire
    can anyone confirm if this is correct
    Black -Heat (+12vdc)
    Black-Heat (-12vdc)
    Blue-Signal (ie connect to my original wire)
    White-earth (connect to chassis)
    __________________
    so i dont blow it up
    May 2006
    Default Re: oxygen sensor wiring
    anyone.... so despreate.
    vic
    Yes thats it except the white goes to E2 of engine wiring sensor earth
    Dave
    Yeah, and technically there isn't a -12V... it's just ground.
    Black - O2 heater circuit ground
    Black - O2 heater circuit 12V
    White - Sensor circuit ground wire
    Blue - Sensor circuit signal wire
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    May 2006
    so with white i can just ground out
    to the body, or it has to go to a specific negative
    remembering the car is just a one wire from the factory
    Yeah, there's no harm in doing that.
    The 1-wire sensor just grounds through the O2 sensor body anyway, but they changed to a 2-wire (with an isolated sensor housing) to avoid relying on grounding through a potentially dirty/corroded thread on the sensor.
    Current rides...
    2) White RA25ST
    it is better to ground it to the earth that is used for the ECU, because the signal is small (0-1V) and any difference in voltage between your choice of ground and the ECU's ground, will result in an incorrect reading.
    you want the ECU to have the best reference possible, and 0.1 or 0.2V out is far too big for it to work properly
    yes chassis could work, but you may as well as least extend the wire to go to the point of chassis where the ECU grounds..
    Then the 4-wire adds a heater element. There was also a 3-wire that didn't have an isolated case and grounded through the case.
    Current rides...
    2) White RA25ST
    Yeah, it would be worth the effort.
    Current rides...
    2) White RA25ST
    May 2006
    ok
    i got plenty of grounding cables going back to the battery, it would be best to come off one of those, as frankly i have nfi where the ecu grounds
    May 2006
    ok finished now, turned out the signal wire had an integrated earth sheath, so i used that as my sensor ground,
    for the power i was under the impression that i could just tap into the alternators on wires with a fuse would be fine, however the battery check light is now on still charging correctly
    but overall good as the engine is now not running uber rich now, but only time will tell if my economy will return
    anyone suggest a better place to tap in ?
    Chiba
    Does the heater stay on all the time normally, or is it only on long enough for the o2 sensor to heat up?
    If it's on all the time, couldn't you just wire the heater to the ignition, via a relay?
    May 2006
    all the time as far as i am aware,
    yes i could do that, looks like the path i will be taking, but it is such a small load (12w) i did not think there would be an issue
    That's about 1 amp, which isn't insignificant, but shouldn't need a relay.
    Obviously if you run it direct from the alternator or battery, then you will want to run a fuse.
    To keep it neat, I probably would have run 4 new dedicated wires to the ECU rather than one to the old connector, one to the chassis, one to the ignition, and another to the chassis. You could just tap all the wires into the loom at the same spot.
    The heater power to the Ignition input of the ECU, and the heater ground to the the ECU gnd.
    The signal to the signal wire, and the signal ground to the ECU signal ground.
    But, there are many ways to skin a cat and the important thing is that your is working now
    Current rides...
    2) White RA25ST
    May 2006
    well i will have to resolve the battery light being on, but i am sure il will sort it out,
    does anyone know where the s2 gets the oxy sensors power from \
  1. 1g-gte Oxygen sensor
    By Z2TT in forum Tech and Conversions
    Last Post: 12-07-2008, 12:00 AM
  2. Oxygen sensor..need a fix.
    By 88FOUR in forum Tech and Conversions
    Last Post: 20-10-2006, 05:29 PM
  3. Oxygen Sensor
    By XiL3D in forum Tech and Conversions
    Last Post: 20-10-2006, 03:57 PM
