Results 16 to 24 of 24
Thread: MX83 Clutch Pedal Fookedness
    vic
    Default Re: MX83 Clutch Pedal Fookedness
    Forums LOL
    Dave
    I used MA70 peddels which I assume are the same and had no problems fitting it all up..
    Only things I had to do was drill the two holes threw the firewall for mounting and then cut a bit off the mounting plate so that it would sit flush against the firewall (as you mentioned the trans tunnel fowles with the backing plate a bit so if you cut the top left corner a bit it all sits flush).. No spacers or washers and it all bolted up fine.. The peddels also lined up pretty well..
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    I fail to see how this can be called bolt up....
    Looks pretty much bolt up to me too
    Seriously not hard overall. Sweet pain in the arse that 99% of people reckoned it was "bolt up"
    Forum Sponsor Conversion King
    Dec 2006
    Whats it out of? if its a70 does it use the factory firewall holes or do you need to add one as the angle looks wrong and it doesn't seem to line up with the top right (looking into the engine bay) hole.
    the JZX90 stuff bolts up to the firewall no problems and no pedal mods etc but the 1 bolt hole to the dash needs modding.
    linden
    A70, redrilled holes.
    Its all working now, but this was because ive had a bunch of people PM me and say "oh, i hear the A70 unit bolts up to the cressy".
    Works, yes, works well, yes. Bolt up, my arse.
    binge toymoder Grease Monkey
    vic
    does the auto brake pedal work or do u need a70 brake pedal box also? and if so is this a bolt in affair?
    ke70 20v drifta 18psi = 230rwkw
    jzx83 cressida, 14psi = TBA
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    You can cut down an Auto pedal to be the right size, but I think this is a rather dodgy way to do it.
    I got an A70 pedal, removed it from the A70 pedal box, and put it in the Cressida pedal box.
    It fitted perfectly, with the right edge (Closest to the accel pedal) sitting in the same position as the Auto pedal, but obviously, its only 5cm wide, as opposed to 10cm. (Measurements are a rough guide)
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
    vic
    ok im half way through fiting ma70 pedals now! it is definately not bolt in! i didnt have the issue of the pushrod length because i cut and welded the pedal below the pushrod hole, thus taking the curve out of the pedal so i get full travel before it hits the firewall. seems to have worked well!
    in addition to this i had to drill the two holes for the master, cut the corner off the bracket to clear trans tunnel and extend tag on bracket for the top bolt to fit correctly.
    on a different subject tho interestingly enough i had trouble finding a slave to suit r154 so i racked my brain to remember what it was that i had seen similar. so i ordered an e30 bmw slave, it needs a longer pushrod and one hole drilled but otherwise looks the goods, the only thing i dont know yet but will confirm later is the sizing in relation to the master. looks a tad biger but im hoping it will work. only cost 45 bux too!!
    cheers tim
    edit: sorry - i thought you were talking about your Supra clutch - my bad.
  1. tinny rattle when braking and/or using clutch pedal
    By gunk in forum Tech and Conversions
    Last Post: 25-06-2008, 04:44 PM
  2. Clutch Pedal Issues
    By HKS_TRD in forum Tech and Conversions
    Last Post: 02-10-2007, 09:17 PM
  3. Creaking/Squeaking Sound on Depressing Clutch Pedal
    By Tham in forum Tech and Conversions
    Last Post: 29-10-2006, 08:04 AM
