Results 16 to 30 of 30
Thread: 2jz-gte aristo with reverse problems
    Jul 2008
    Finland
    Default Re: 2jz-gte aristo with reverse problems
    Thanks for the info
    Now i like to trie another thing
    If we will make numbers of things that can be wrong that make the reverse don't work.
    Like this.
    1: The Ecu give the solenoids no pulse because a wire is loose
    2: Something wrong with a solenoid.
    3: blabla bla
    4: 5: 6: 7:
    This kind of stuff so it is easier for us to trie to find one of this things that can be wrong And others to check out if they have the same fault.
    If it wont go into reverse the transmission was probably incorrectly assembled and it will need to be done properly.
    Jealousy is a curse
    Quote Originally Posted by madmont
    The fact that the auto works when the solenoid plug is unplugged points to an electrical issue...
    1) Check your wiring:
    --> Do you have +12V at the R pin on the engine ECU when the shifter is in the R position? (And the other positions such as L & 2...)
    2) Check your wiring:
    --> See above
    Another link for more information for you... (so you can continue to avoid checking the voltage at the ECU pin for a longer period of time? )
    Lexus GS300 Repair Manual RM406.zip
    Note this is USA, so some things are slightly different...i.e. the auto has a shift cable... but there is a lot of info there that should be able to help... in particular pages 29 & 49 and of "Automatic Transmission"
    Jul 2008
    Finland
    The link don't work anymore and another thing were is the Ignitor Pinouts lokated in the car? is it near the dashboard?
    Quote Originally Posted by Phantom83
    Lancy boy has taken the link down it seems!
    And another thing were is the Ignitor Pinouts lokated in the car? is it near the dashboard?
    No, it isn't near the dash.
    It's in the engine bay, on a 2JZGTE it is on the turbo side of the engine, it usually bolts near the strut tower...
    Jul 2008
    Finland
    do any one have the Lexus GS300 Repair Manual RM406 ? So i can get it? Ok. then we will try to find the Ignitor Pinouts
    Jul 2008
    Finland
    Is this the same?
    Is this the same?
    Yes.
    And in my previous post I even told you where on the stock JZS147 Aristo body loom plug those wires came out on....if you are using the aristo main body loom plug....
    http://www.toymods.net/forums/showpo...00&postcount=8
    Jul 2008
    Finland
    hmmm i have a problem with this cabel I did have seen this before and did search for it in the engine room and did ask my friend that did do the most of the electical work. Were is this cabel were and he did say it have been chopped of.. And sent with the junk to the junkyard so there is that and they dont find it. So now i need the colours for the cabels so i can get this solved. Any one that can help? Wilbo? I need the colours to the gearbox
    I avoid using wire colors, they change too much.
    I suggest that you trace back from the plug on the auto to your 'cut' wires with a multimeter.
    The below diagram should help.
    Jul 2008
    Finland
    thanks again wilbo Your a hero
    Jul 2008
    Finland
    Look at this. this is why a don't can understand why there are problems when the Ecu know what gear it is in. And ect.
    Does the dash always say it is in D?
    Anyway, the dash is a SEPARATE issue to the gearbox.
    I've suggested how to fix the gearbox problem three? times now in different manners...have you done / checked what I've (and others) have suggested?
    If not my care factor is going out the window
    Jul 2008
    Finland
    No it will say the gear that i have in if i have in P . D N 2 L so it kind of strange the computer need to know somehow that i have in exampel 2 when i have in gear 2
    Why i need to know this was because my friend didn't trust me when i told him what you say So he will get the answers he need.
    So you are suggesting to me that Toyota put the D, 2, L and NSW pins on the ECU simply to take up the extra space?
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. What again?? 2JZ water pump onto 1JZ, have I got the wrong one?
    By ReQuieM in forum Tech and Conversions
    Last Post: 26-04-2008, 05:17 PM
  3. 2JZ with 1JZ ecu?
    By SL666 in forum Tech and Conversions
    Last Post: 17-01-2008, 05:14 PM
  4. 1jz chaser changed to 2jz aristo Front Sump?
    By DenZel in forum Tech and Conversions
    Last Post: 29-09-2007, 11:31 AM
