Results 1 to 15 of 16
Thread: What again?? 2JZ water pump onto 1JZ, have I got the wrong one?
    Default What again?? 2JZ water pump onto 1JZ, have I got the wrong one?
    Hi all,
    I ordered in an after market 2JZ-gte water pump to ditch my 1JZ one, but when I lined the supplied water pump gasket over the spare aristo 2jz hydro pump they were different around the impeller.
    Do I need the rear housing (although a search on tells me no)?
    Is the aristo 2jz hydro water pump different to the 1j?
    or have I been sent the wrong water pump?
    Cheers!
    Malicious
    Photographer and Backyard Mechanic Rinmax's Avatar
    Default Re: What again?? 2JZ water pump onto 1JZ, have I got the wrong one?
    Well even though the model are slightly different, I have recently fitted a brand new 2jzgte water pump to my 1jzgte soarer. No problems what so ever, it was a straight fit.
    Only difference I see is that I used genuine Toyota parts.
    "It's an ingenious solution to a problem that should never have existed in the first place." - JM
    "A Ferrari is a scaled down version of god while a Porsche is a Beetle with mustard up its bottom." - JC
    Yeah I'm thinking that I may have a GE pump instead as the mount points that line up with the front of the engine appear to be correct but the ones that goes around the impeller are off. Also the impeller seams quite a bit smaller then 2JZ-GTE Hydro pump I'm comparing it too.
    Yah for buying shit OS over the net. Was cheap. May turn out to be twice as expensive.
    Anyone have a comparison of the gte to ge pumps? pwease
    Malicious
    When I did mine I used a genuine pump that came with the rear housing, bolted up perfectly.
    The rear housings are different, hydro to normal pump.
    You will need the rear housing to suit a non hydro pump.
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    These pics I took during my conversion from Hydraulic to Standard may help you Identify.
    Not sure how "cheap" you got yours for, but from Toyota Australia, retail is around $160.00 complete. (trying to find the invoice for the trade price)
    correct part numbers are as follows..
    2JZ-GTE (JZA80) Water Pump (non hydraulic) -16100-49846 (includes seal and gasket)
    Water Pump Pulley (non hydraulic) -16371-46020
    Aristo 2JZ-GTE Hydro Water Pump
    Front of 2JZ-GTE to show bolt holes etc
    2JZ-GTE NON-Hydro Water pump
    Shit looks like I may have a gte but just no rear housing. Thanx for thos picks sleeper, the one of the front of the engine appears to be right on the block but the ones that I think are wrong are the ones that goto the rear housing.
    Dam, seller has offered to take it back and refund but it cost nearly as much to ship it as it did to buy it lol!
    Anyone want a 2J water pump minus the rear housing?
    Malicious
    What you need is this...
    The part number is there, might as well see if they are cheap from toyota?
    Cheers wilbo! I might as well see if my local toyota is in a helpful mood for once lol!
    Malicious
    which dealership do you use?
    Used to goto brighton, but quite frankly they are a pack of see you next tuesdays. Oakleigh were really helpful last time, so I'll give them another bash.
    Malicious
    Yeah I've heard good things about Oakleigh, Brighton I've never had any dealings with. A good one for those out east would be Nunawading, good buch of blokes that will go the extra mile, if your serious.
    As I said, the WHOLE pump and o-ring and gasket is about $160.00
    (less for trade)
    If you can't get any satisfaction from your dealer, let me know and I will go down to my local dealer and get it for you.
    Thanx for the offer, but a mate locally has a spare one. Ironically its off the spare engine that I sold him not too long ago! Doh!
    Seriously thanx for all the help guys! When I did a search there was something mentioned about the rear housing but no proper answer (well that I found ), so hopefully this thread will be of some use for others that go this route.
    Malicious
    I bought this one at a swap meet, Anyone got any clues as to which J series it's from?
  1. Dry-sump construction
    By Billzilla in forum Tech and Conversions
    Last Post: 19-10-2007, 01:51 PM
  2. 2jz water pump help
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 26-02-2007, 10:17 PM
