Results 16 to 29 of 29
Thread: 4A - W* Bellhousings AVAILABLE from ToyCool Garage (Phillipines)
    KE20XX Grease Monkey charade_16v's Avatar
    Jul 2007
    Default Re: 4A - W* Bellhousings AVAILABLE Locally!
    OK,
    $380 delivered, has clutch fork opening on INTAKE.
    Easy to deal with, great service.
    Now the test fit!
    Jul 2007
    All received.
    Rhett is a great guy to deal with, and i'd recommend him to anyone.
    Takes 7 weeks to deliver, as he uses the cheapest postage to keep costs down. and for $380, who would argue??
    Bellhousing looks fantastic!! Can't wait to fit it.
    Will post up pics tonight.
    Mark M
    Is a Self Employed Grease Monkey wombat's Avatar
    Very interested to see how this fits. Does he have more of them available that you know of?
    Jul 2007
    hahah so am i, as far as i know he has more available.
    Mine should be fitted within a few weeks (by Matt @ HiTech Modifications, Penrith), so i'll definately post up plenty of piccies.
    [email protected] is his contact (Rhett Del Rosario is his name).
    From what i've been told, it fits perfectly...apparently the only mod that is needed is a slight grind to fit the 212mm flywheel, which i've herd is the same for most of the aftermarket bellhousings available.
    Great bloke to deal with, very helpful and a man of his word.
    well worth the 7 week wait to receive it!
    MM
    so.. is this no longer "bellhousings available locally"??
    Jul 2007
    correcta-mundo!
    hahaha will change the heading...
    cheers,
    MM
    SC14 7AGZE Grease Monkey
    Jun 2007
    FL
    Quote Originally Posted by charade_16v
    You're mistaken. He told me its the 224mm (4AGZE) flywheel that needs grinding. The 200mm 1984-1987 bluetop 4AGE and the later 1988-1998 212mm redtop 4AGE, 20v 4AGE, and 7AFE all fit fine.
    My flywheel is a 212mm 7AFE and it fit perfect when I test fit it to my block. Anyway, good luck with the W58.
    SC14 7AGZE build: http://beasted86.webs.com/
    Hoppers Crossing
    Default Re: 4A - W* Bellhousings AVAILABLE from ToyCool Garage (Phillipines)
    nice one mm
    Jul 2007
    hi all,
    Thanks Turbo4agte for rectifying that mistake.
    how do i post pics up in here??
    MM
    Balloon Slayer Backyard Mechanic jimmmayyy's Avatar
    Apr 2007
    where abouts in philippines is he based? i'm living over here atm.
    what? Automotive Encyclopaedia EVOSTi's Avatar
    hi all,
    MM
    imageshack.us
    binge toymoder Grease Monkey
    vic
    just for anyone who is a cheapskate like me... i used the back half of a w-55 bellhousing and front half of 4a t-50 bellhousing, made a jig for input shaft alighnment, had them both milled flat at the point where the best matched and welded em together, it works perfectly and only cost me 150 bucks(considering i already had both bells) and it fits the 224mm gze flywheel too once u grind off all the old ribbing!
    jus thought id let u all know...
    p.s. what is ppls opinion on what flywheel/ clutch setup is better for holding power? gze 224 or 20v 212... i had a ceramic 212mm 20v one with 1900lb pressure plate and it slipped so i dont want my next clutch to slip!!!
    cheers tim
    ke70 20v drifta 18psi = 230rwkw
    jzx83 cressida, 14psi = TBA
    Good one ae71 kid, that is the method i've been planning on using. Glad to hear it was successful.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    highly underrated Backyard Mechanic
    Feb 2010
    I got one of these bellhousings on the way I just ordered it a few days ago I probably need one my 4agte puts out close 170 at the wheels and im not gentle with gearboxes. has anyone come up with what fork you use with this? I have a w58, w57 and t50 clutch fork it would be good if I could use one of those forks.
    RT104 with 4AGTE
    Some assembly required
  1. 253 v's 308 bellhousings (sorry)
    By JustenGT8 in forum Tech and Conversions
    Last Post: 19-10-2007, 08:01 PM
  2. w50 bellhousings
    By sam-131 in forum Tech and Conversions
    Last Post: 24-11-2006, 05:32 PM
  3. R154 Bellhousings
    By ToranaJudd in forum Tech and Conversions
    Last Post: 16-08-2006, 10:02 AM
