Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
Thread: Conversion Trouble 1UZ into Hilux?
    Jun 2007
    Default Re: Conversion Trouble 1UZ into Hilux?
    Yeah mick08 pics wood be awesum, help with the ideas tank... Cheers
    Apr 2007
    wilcannia NSW
    Quote Originally Posted by nilprospects
    This is what i've done to mine, but belt slips when i start engine in the morning, and slips with lights on high beam when engine falls below about 1000rpm. Next van i do will be superchrged so i'll start looking into gilmore pulleys.
    have you considered altering the setup a bit so more of the belt wraps around the alternator pulley ? it would probably cure the slipping.
    Junior Member Grease Monkey nilprospects's Avatar
    Sep 2008
    Quote Originally Posted by briney
    yeah, exactly what I did, bypassed tensioner using shorter belt and pivoted alternator thru top bolt, and made a custom bottom mount adapter.
    Jun 2007
    Moved the luxy last weekend & p/steer fluid went everywhere. So fitted up a EL falcon transmission cooler up on the non pressure side & hopefully this fixes this little problem????
    Jun 2007
    Radiator all plumb up just had to move abit back to fit thermo fan. Hopefully next week I'll send her off to get exhaust system fitted...
    Jun 2007
    Exhaust system all done, twin 2.5" then into a single straight threw muffler then dumped justn over the diff. Not too loud to cause any problems but enough to give it a nice note at revs....
    Jan 2008
    queensland
    do you have any audio of the zorst mate? i plan on having 2inch -2.25 max out of the crown logs then onto a 2.5 single over the diff to keep some of the torque that these small V8s lack down low,madmont was telling me he reduced his exh down to 2inch from 2.25out of the headers cause 2.25 was to big and it lacked some torque,it'l be interesting to see how yours goes compared,any pics of how the pipes were run and where the cats are if any, where did you end up mounting your ecu?
  8. #38
    wa
    What type of radiators are you guys running ,do you have any pics of your setups.
    Im probably looking at a custom ally one but if there is one you can buy on ebay that is close it might be worth a try .
  9. #39
    Quote Originally Posted by 2jzhilux
    Which motor are you using?
    Jealousy is a curse
  10. #40
    Jun 2007
    Front mounted sump engine from a LS400/Celsior. I got a new LN111 hilux radiator off litldv8 here on toymods modifidied both inlet/outlet elbows on rad & got a pipe mandrel bent to adapt to lower rad elbow. The exhaust I've seen guys with twin 3"systems pretty loud but still went well. Myself I'm not after performance hence why its all standard wiring/ECU auto & in a luxy.... The exhaust like i said before has a nice note at idle & under a few revs but nothing that is going to give me alot of trouble with police. The headers I've cut down firstly to fit inside upper control arms,basically a log manifold & secondly my brothers best mate does performance extractors exhaust systems & just for a custom extractors made up & HPC coated he charges $1500 - $2000 thats tuned length extractors & really didn't want to spend that much on the exhaust...The ECU is mounted on the passager side on the bottom of the firewall. 'I've just got to make up cover for it & then put the carpet back over it... I'll try my best this weekend to get some pics of her so far....
  1. 1G Conversion into a pre 85' hilux
    By Rat_Tilly in forum Engine & Driveline Conversions
    Last Post: 17-08-2011, 11:50 AM
  2. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  3. quadcam 1uz into a 91 hilux
    By aristo_newy in forum Tech and Conversions
    Last Post: 28-09-2008, 07:13 AM
  4. MA70 --> JZA70 Conversion
  5. YN57 hilux power steer conversion - how to?
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 13-11-2006, 11:15 AM
