I mean, it stays at 4% - never goes above that.Originally Posted by Hydra
Hey guys,
I'm stuck! I can't get my 1jz out of what would appear to be limp home mode. It's sparking OK, but I hooked up a duty cycle meter to the injectors and it would hit about 4% (just above idle) and die in the arse. It's like hitting a fuel cut. If I let off the throttle after this cut occurs, the engine springs back to life. It's just anything more than a little throttle and/or 2500rpm kills it. If I open the throttle fairly quickly it just stalls.
The Fuel system is working as far as fuel pumps go. What puzzles me is that the duty cycle on the injectors hits about 4% and goes no higher at all, no matter what throttle I dial in.
This has lead me to think that the TPS may be either faulty, or not getting power at the right places. Does anyone know what pins should have what power/signal?
The MAP appears to be getting power - no error codes are getting recorded either. As far as I know everything is hooked up the way it should be. There are no vacuum leaks to speak of.
I'm really stuck here - I need help figuring this one out!
Hydra
JZA61 Celica XX
Hydra
JZA61 Celica XX
Sounds like a MAP sensor problem to me. This is the primary means of determining engine load, not the TPS. Make sure the sensor is getting a clean vacuum signal and check the output voltage is in the correct range.
Norbie!
www.norbie.net
Ok, sounds like a good place to start! What range should I expect?
The MAP is connected to the intake via some adaptor thing - is this the correct place?
Hydra
JZA61 Celica XX
Here's a pic - the black thing that bolts in:
Hydra
JZA61 Celica XX
FWIW, I just tried the MAP sensor on a few other vacuum points - still no go.
Hydra
JZA61 Celica XX
				intercooler pipe/ hose ?
				Is the map sensor reporting correct values?
Correct values are listed in the Toyota Mechincs Guide.
Daily: Toyota '05 Rav4 Sport
Doubt it'd be the intercooler pipes/hoses - MAP shouldn't be affected by that.
MWP - got a link to it by any chance?
Hydra
JZA61 Celica XX
Check your cooler pipes as mentioned.
I run a MAP, and when I blew the cooler pipe that goes between FMIC and Throttle, my engine displayed the exact same symptoms.
Have you also reset the ECU?
				Disconnect the battery for a while (10-20 mins) so the ecu resets and try again, if that fails try manually resetting the ECU by using the Diagnosis pins!
ECU has been reset many times since the engine was put it. The car sits there with the negative disconnected while i'm at work since it's up on stands.
The pipes are fine, no leaks that I can find.
No diagnostic codes are showing - I wish there were so I could just fix the damn thing!
Hydra
JZA61 Celica XX
Found the mechanics manual thigo:
http://www.autoshop101.com/forms/h35.pdf
Off I go to test...
Hydra
JZA61 Celica XX
Seems to be working OK - it was sitting around the 2.4-5V mark on the PIM pin while the engine was off, 1.3-4V while the engine was idling. Revved the engine, it hit the 2.4-5V mark as the engine started it's rev-cut thing.
So I can only conclude that it knows how much air is going in... but that doesn't help.
Hydra
JZA61 Celica XX
I did pull the cover off the ECU early on - I didn't notice any form of leaking or corrosion from the capacitors thankfully. I am setting this aside as a potential problem for the moment...
Something that would be very awesome would be a pin-out for the ECU with the voltages to expect on each pin. I've seen this before in TSRM's but I can't find one for the 1jz-gte anywhere.
Hydra
JZA61 Celica XX
