Page 1 of 9 123 ... LastLast
Results 1 to 15 of 135
Thread: 1jz wont rev past ~2500rpm *SOLVED*
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Angry 1jz wont rev past ~2500rpm *SOLVED*
    Hey guys,
    I'm stuck! I can't get my 1jz out of what would appear to be limp home mode. It's sparking OK, but I hooked up a duty cycle meter to the injectors and it would hit about 4% (just above idle) and die in the arse. It's like hitting a fuel cut. If I let off the throttle after this cut occurs, the engine springs back to life. It's just anything more than a little throttle and/or 2500rpm kills it. If I open the throttle fairly quickly it just stalls.
    The Fuel system is working as far as fuel pumps go. What puzzles me is that the duty cycle on the injectors hits about 4% and goes no higher at all, no matter what throttle I dial in.
    This has lead me to think that the TPS may be either faulty, or not getting power at the right places. Does anyone know what pins should have what power/signal?
    The MAP appears to be getting power - no error codes are getting recorded either. As far as I know everything is hooked up the way it should be. There are no vacuum leaks to speak of.
    I'm really stuck here - I need help figuring this one out!
    Default Re: 1jz wont rev past ~2500rpm
    Quote Originally Posted by Hydra
    I mean, it stays at 4% - never goes above that.
    Sounds like a MAP sensor problem to me. This is the primary means of determining engine load, not the TPS. Make sure the sensor is getting a clean vacuum signal and check the output voltage is in the correct range.
    Ok, sounds like a good place to start! What range should I expect?
    The MAP is connected to the intake via some adaptor thing - is this the correct place?
    Here's a pic - the black thing that bolts in:
    FWIW, I just tried the MAP sensor on a few other vacuum points - still no go.
    perth
    intercooler pipe/ hose ?
    Is the map sensor reporting correct values?
    Correct values are listed in the Toyota Mechincs Guide.
    Doubt it'd be the intercooler pipes/hoses - MAP shouldn't be affected by that.
    MWP - got a link to it by any chance?
    Check your cooler pipes as mentioned.
    I run a MAP, and when I blew the cooler pipe that goes between FMIC and Throttle, my engine displayed the exact same symptoms.
    Have you also reset the ECU?
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    Mar 2008
    inner west syd now!
    Disconnect the battery for a while (10-20 mins) so the ecu resets and try again, if that fails try manually resetting the ECU by using the Diagnosis pins!
    ECU has been reset many times since the engine was put it. The car sits there with the negative disconnected while i'm at work since it's up on stands.
    The pipes are fine, no leaks that I can find.
    No diagnostic codes are showing - I wish there were so I could just fix the damn thing!
    Found the mechanics manual thigo:
    http://www.autoshop101.com/forms/h35.pdf
    Off I go to test...
    Seems to be working OK - it was sitting around the 2.4-5V mark on the PIM pin while the engine was off, 1.3-4V while the engine was idling. Revved the engine, it hit the 2.4-5V mark as the engine started it's rev-cut thing.
    So I can only conclude that it knows how much air is going in... but that doesn't help.
    I did pull the cover off the ECU early on - I didn't notice any form of leaking or corrosion from the capacitors thankfully. I am setting this aside as a potential problem for the moment...
    Something that would be very awesome would be a pin-out for the ECU with the voltages to expect on each pin. I've seen this before in TSRM's but I can't find one for the 1jz-gte anywhere.
  1. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  2. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 04:04 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
