Results 1 to 5 of 5
Thread: Halfcut compression test numbers
    Default Halfcut compression test numbers
    Hi all,
    Im looking at buying a 1UZ halfcut (92,000 on the dash odo).
    I had the guy selling it do a compression test and this is what he reported:
    cyl1 - 180
    cyl2 - 155
    cyl3 - 155
    cyl4 - 145
    cyl5 - 140
    cyl6 - 145
    cyl7 - 150
    cyl8 - 155
    This is an engine that hasnt be run in who knows how long, and the test was done cold.
    Opinions?
    Default Re: Halfcut compression test numbers
    I've seen some pretty average compression tests out of engines that haven't been run in a long time...I know this is vague and sweeping, just hoping to give you some more info!
    But those figures look good to me...the are even across the cyls, with a bit of a question mark over Cyl 1 being higher...
    Forum Sponsor Conversion King
    tap the buckets to free them up and do a leakdown test on it, that will tell you more about condition.
    linden
    Jun 2008
    If it is possible to start the engine, run it for a few minutes and once warm give it a few revs then re-test, a leakdown test is better.
    I tested a 1j 2 weeks ago that was in a cut, 3 of the pots had between 30 - 50 psi, after we ran it for 10 minuted, we retested, all pots then measured between 190 - 195psi ;-)
    Ill push them to see if we can get it running... but i have an idea they wont
    They will give me a warranty on it.
  1. Compression Test Results for 20v ST
    By Escy in forum Tech and Conversions
    Last Post: 28-02-2007, 10:42 AM
  2. Compression test results
    By minxgirl in forum Tech and Conversions
    Last Post: 16-11-2006, 07:05 PM
  3. 1ggte COMPRESSION TEST....readings.....SORTED!, cheers
    Last Post: 23-08-2006, 10:12 AM
  4. What do these compression test resaults mean...
    By doobs in forum Tech and Conversions
    Last Post: 13-06-2006, 08:41 AM
  5. 20v compression (compression test)
    By 2revup in forum Tech and Conversions
    Last Post: 20-03-2006, 05:06 PM
