Three weeks ago I just finished working with the RTA after 30 years. I've written many of the policies and standards including the pink slip rules back in about 1994. For 12 years I was on the committee which wrote the ADRs. I plan to become an engineering signatory.
The item you have here is commonly known as a Rose Joint.
I doubt if there is anyone left in the RTA who could give you an informed answer but it would be something along the lines of:
(1) No
(2) What's sealing the the rose joint wearing surface to keep the dirt & water out. (However, there is no standard for this. The rules only require it to be in working condition. If the joint wore out every 10 minutes and you had to change it every 10 minutes the RTA could not do anything provided it was OK during that 10 minutes although they would want to argue with you on this point but you should win but you might have to go to Court.)
(3) What would the vehicle manufacturer say about the joint - how about, No. The RTA would use this in its defence.
(4) How do you know it is suitable? I would not go to Court using a statement from an unqualified person behind the counter who says they've sold thousands and no one has ever returned one.
(5) Ask the manufacturer of the rose joint to provide evidence of suitability including dynamic fatigue testing to a known Standard and a comparison with the original component. (They will most likely not be able to supply this). A simple breaking or tension test would not be good enough.
(6) Note that the rose joint does not have a full taper but a short fat tapered ring on the bottom. There is a strength issue here and it might deform the face of the original tapered hole.
This is the sort of thing that would create a lot of discussion in a Coronial Inquiry which is one of the areas I'm going to work in.
The issue is that everyone is going to say they are great and never fail but ask them to give you some hard copy proof. If you're driving at 100k/hr and one breaks, think about what your going to do have to do to correct the car in a microsecond with one wheel already on full lock.
Remember car maufacturers do a great amount of on-road testing and test rig dynamic testing yet they still have recalls. What has the maker of your rose joint done?
