MonthOriginally Posted by ed_jza80
sounds like hell
I am a bit confused over this, how does the shim type affect the way the valve opens?Originally Posted by abently
also I thought that all non powdered metal rods where forged?
sounds like hell
wow missed that bit on my skim reading... mate, your score another point for bad advice... that statement above is complete rubbish!Originally Posted by abently
justen... shortest month of the year, i can cope... need to lose the weight!
../delete/ban
tech moderator
I let abently's comment go thru to the keeper......not like it's anything unusualOriginally Posted by ed_jza80
everything in moderation Ed (well almost everything) and get back on your mtn bike![]()
Biggest lawl in a while.Originally Posted by abently
I was under the impression that the only reason to run shim under/solid buckets was so you could use more aggressive ramp angles and more lift, without the risk of spitting a shim...
I'm all ears if there are other reasons though...
just pumped the tyres up yesterday! lol...Originally Posted by JustenGT8
its he resurrection of the last parts of my old race bike - very sentimenta!
../delete/ban
tech moderator
That's correct and therefore you can run less duration for the same HP as a result...Originally Posted by Gavatron
I guess common sense isn't so common.
so very trueOriginally Posted by abently
../delete/ban
tech moderator
Selective hearing or is that selective reading now ? lol
If you viewed this > ( http://www.camshaftshop.com/catalogu...07-g-camshaft/ ) you would have noticed that they don't specify shim under bucket conversion, like they do here > http://www.camshaftshop.com/camshaft.../3s-ge-gte/37/Originally Posted by abently
To their credit though, they do state here > ( http://www.camshaftshop.com/camshaft.../1uz-fe-v8/33/ )
Eitherway looks like Denzel has now a supplier for the conversion Kit.we have in stock shim under bucket kits with retainers and single or dual valve springs.
actually dude, the first link you post does specify you "must use shim under bucket setup".
I quote from your first linkThat is an example of how "selective" your reading isApplication: Lexus / 1UZFE, fully modified racing engine, ultimate cam for 430-470HP NZ A Grade stock car, must use shim under bucket setup.
EDIT: I just went through their site, there are a few contradicting typo's. I would prefer to trust someone with a bit of actual experience with the 1uzfe rather then possible erroneous text on their website.
Best to email them for sure tho...
not again?Originally Posted by abently
selective thinking? poor link between brain and typing?
it's easy to say "yeah, see i was right after all" when others come and fill in the gaps you leave due to not knowing in the first place![]()
i used to think abently was a KM AE, but KM can't speel sew gud![]()
Ok, keep it on topic... sorry but my service here isn't paid so responsibility = nil. Although I do try to be accurate for the OP sake.
I've said what I had to say twice now, so that's the end of this thread for me.
If you can get stock drive ability from the 294 deg cams, then go for it seriously. Its the only way to make more power out of an N/A Engine along with more RPMs.
hopefully those conversion kits will include the 1uzfe, and werent just talking about 3sgte, though i been told most of those parts are inter-changable,
i cant seem to find where they say it though, if i click on your link just refers me back to the home page.
previous toyo's - 2 celica's, 5 soarer's, cressida, corolla, 3 supra's, 2 celsior's
previous toyo engines - 18rc, 18rg, 7mgte x2, 1uzfe x5, 4agze, 1jzgte x2, 1ggte x2
current toyo's- toyota supra jza80
o'rly?.....Originally Posted by DenZel
../delete/ban
tech moderator
yes iv been told some of the later 3sgte stuff will work.Originally Posted by ed_jza80
shed some light on what parts can be used for the shim under bucket conversion then please? Simplest and cleanest solution if there is a such a thing with this conversion. Looks like either way, something has to be aftermarket or machined.
edit - went through your site again, noticed AeroPC has performed the swap, and he's in perth too. Though not sure if they are a workshop or just a racing team.
