Hi denzel,
Have a look at this > http://www.trdparts.jp/english/parts_engine-3s-ge.html
That tuned Engine dyno plot, I assume, is using the 296 deg camshafts. You can see how Power & Torque isn't better till after 6500Rpm.
So with that in mind, unless you have had the Cylinder Head ported to suit a 9000Rpm limit (25m/s piston speed), I strongly recommend you keep to a 272 degree camshaft with as much lift as possible and max ramp rate (i.e. shim under bucket conversion).
