Results 16 to 19 of 19
Thread: increasing boost
    Junior Member Grease Monkey Pr0j3kt_SuPrA's Avatar
    Default Re: increasing boost
    exhaust system usually ups the boost alil too and doesnt require a boost controller
    The ultimate ghetto way is to put a "calibrated" hole in the hose going into the actuator. Start small then get larger until you have reached your desired boost level. Allows the air to bleed out of the hole instead of restricting the air into the actualor
    Or one marginally less ghetto set up is to use a fish tank air line tap as the adjustable bleeder which is less than a dollar. Or use a garden sprinkler system dripper inline adjuster. does the same thing as the fish tank gear but slightly more robust.
    Both a well and truly ghetto and considering how cheap bleeders and gated valves are there isn't really and excuse to use one.
    If you're that broke you can't afford $30 for a cheapo turbotech controller or such then chances are you're too broke to afford the extra fuel usage increased boost will provide you
    im a hardcore Backyard Mechanic LO01UX's Avatar
    Jun 2007
    na im not the tightass
    i went and got a power-up or sumthing boost controller front autobarn 2day cost me $50
    but then on talk to rod (toyman) realised my turbo needs replacing due to the fin being f*#@ed
    BUILT NOT BOUGHT
    (\__/)
  1. boost creeping issue..
    By renxun in forum Tech and Conversions
    Last Post: 11-03-2007, 08:32 AM
  2. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  3. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  4. Boost Leak Tester
  5. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
