Results 1 to 4 of 4
Thread: Temp guage acting wierd
    Junior Member Automotive Encyclopaedia JZA70R_92's Avatar
    May 2008
    Default Temp guage acting wierd
    Hello Guys
    1GGTE
    My temp Guage would go to halfway on the digidash then all of a sudden up to HOT......
    at 1st i thought it was the temp sensor so i swapped in a working one still had problems...so i cleaned out radiator changed coolent...then i found out by accident when i unplug the OXY sensor the temp goes immdiatly to halfway....now what the hell is causing that for now ive left the oxy senso disconnected....also the car doesnt run hot at all...top hose is hot and bottom hose is coolish...
    1992 - JZA70 STOCK - SOLD
    Default Re: Temp guage acting wierd
    Gauges doing weird things nearly always means a bad earth. Check all your ground points.
    May 2008
    coolies will check when i have time....still does it...
    Junior Member 1st year Apprentice turbo_gze's Avatar
    Same thing happened with me bad earthing was the problem.
    My temp gauage was like a 2nd tacho.
  1. Reistor to change water temp guage range?
    By Bowlsclubboy in forum Tech and Conversions
    Last Post: 13-03-2008, 05:48 PM
  2. KE70 Water Temp guage
    By CHB in forum Tech and Conversions
    Last Post: 27-12-2007, 12:34 PM
  3. engine temp guage
    By pushrod_POWA in forum Tech and Conversions
    Last Post: 12-08-2006, 11:07 AM
  4. 1G aftermarket temp guage install.
    By Mr Multivalve in forum Tech and Conversions
    Last Post: 22-06-2006, 06:47 PM
