Page 29 of 33 FirstFirst ... 192728293031 ... LastLast
Results 421 to 435 of 481
Thread: Celica Brake Upgrade
  1. #421
    Default Re: Celica Brake Upgrade
    whoops, wrong thread.
  2. #422
    to further my rotor enquiry, i rang the mate at repco, blank rotors are $120 ish each, and available around the end of janurary. i'm gonna try and track down a 2nd hand rotor from the wreckers to test fit a set up... stay posted.
    '77 RA28LT #2 ← 2.2L 18RG...
  3. #423
    Not sure if you guys are aware but I transferred the DBA catalogue into excel for easy sort and search. The link is below:
    http://www.v-eight.com/multimedia/xls/DBA_Catalogue.xls
  4. #424
    ahhhh sweet... thanks heaps.... +rep for that! is that all the catalogues? or just local or international?
  5. #425
    I like Stuff Backyard Mechanic mikie's Avatar
    very +rep worthy
    does anyone know what the widest disk is that a Ln106 caliper can take.
    also the Ln106 takes a 302 mm diamiter disk, so why exactly are people fileing them out.
    if i missed something plz let me know, but it just desn't make much sence to me.
    cheers Mike
  6. #426
    probably cause the mounting for the xt130 strut is further in than were the ln106 caliper mounts on the luxy.
  7. #427
    the hilux calliper i have (think it's LN106) won't take anything thicker then 20mm, (posted a list of those rotors on the previous page), and they won't take a 302mm rotor when they're mounted to the corona strut, the strut means the calliper is mounted closer to the wheel center. if you wanted to space them out you'd be laughing though... but easier to machine the disc.
  8. #428
    making brackets should not be much of an issue, has anyone looked at using rx8 rear discs, they are vented 18mm thick and the hat size is 43mm much like the pug rotor, the main diff being that its 300mm big. thoughts???
    cheers mike
  9. #429
    what sort of caliper would you mate to that.
    the whole corona pug idea is biggest with minor custom work.
    300mm rotor would require custom caliper bracket .... then you might as well look at
    other ones etc ... becomes a larger exercise.
    but none the less BA @ 18mm ... very good to know.
    Black Betty >HERE!<
    (\__/)
  10. #430
    If you are going to 300mm discs then just ditch the C/P/H combo and use Mazda RX7 Series 4 calipers, much lighter and lower profile.
  11. #431
    though bloody hard to get ahold of... one mazda wreckers i spoke to suggested they don't part with series IV calipers for less then $400 a pair...
  12. #432
    I think Takai means Series 5 as Series 4 use a 276mm disc whereas the 5 uses 294mm. If you could afford it, the 276mm Peugot rotor + Series 4 calipers would be great brake package. I considered it but at $400 plus another $300 for rebuild them it was too pricey for me. Instead I'm going to use either larger Pug or rear RX7 rotors with Commodore VP calipers. They are alloy and cheap; paid $40 for a complete set (front and rear) and at $50 a caliper to rebuild it's a very cost effective option.
  13. #433
    been to the wreckers today to look at some hilux and landcruiser calipers and they are damn heavy. rx7 s4/5 seem to be popular so im gonna start hunting around. Any on else know of any other 4pot alloy calipers that are attainable by the average person, obviously z32 but these are hard to come by.
    cheers mike
    googleing now
  14. #434
    z32 are the same as the skyline 32 callipers AFAIK, and they shouldn't be hard to get ahold of at all, last time i checked ebay had a pair for $250, but they're still a bloody heavy calliper.
  15. #435
    I got my rx7 s4 calipers for $250 from japan.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 25-07-2018, 12:43 AM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 03:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
