Page 22 of 33 FirstFirst ... 12202122232432 ... LastLast
Results 316 to 330 of 481
Thread: Celica Brake Upgrade
  1. #316
    Default Re: Celica Brake Upgrade
    Quote Originally Posted by mikie
    i have had a look around the froum but cant seem to come up with anything so i will ask here. does anyone know what 5 stud hubs will fit the rt132 strut/stub axle, i have read that ms65 may fit but im not sure and i wouldnt use these as they are not vented.
    Cheers Mike
    MS65 will give you a 5 stud hub. Then you go with a disk / calliper combo.
  2. #317
    broom broom Automotive Encyclopaedia poida's Avatar
    How much extra for teh slotted? or how much for a brake shop to do?
  3. #318
    I havent looked into it much, but the dude i got my gear off told me its running Falcon hubs??? BA Falcon ones i think... Ill double check but worth getting some numbers on. I also think they are same stud pattern as the hilux diff!
    So thats a double bonus
    Jase
    JZA023
  4. #319
    Junior Member Backyard Mechanic rob1's Avatar
    Tas
    So besides the old pug/hilux/etc conversion has anyone got a good combo for original struts? I want to keep the orig. ta22 struts but upgrade the brakes. If your adapting the rn25 lux diff it makes sense to keep the 5 stud rear end, as I've heard it's easy to adapt coon front brakes to a '22. (being the same stud pattern as the rn25) The engineer I am getting to put the rn25 diff into the ta22 said he can easily adapt coon discs and 5 stud pattern to my car on the front, trouble is I just bought some 114.3 15's for it!
  5. #320
    Santa came and delivered a present to the brake shop i use:
    Im on the hunt for RT132 stuff tomorrow.
  6. #321
    go out to u pull it on womma road up north there are tons of them
  7. #322
    Bah if im doing UPI run ill go to Lonsdale
  8. #323
    i havent been down there yet, is it better?
  9. #324
    No idea, i havnt been there. Not going now, sourced XT130 struts and LCAs this morning. Picking up tomorrow.
  10. #325
    When installing the strut with coil-overs do i still need to put in the old spring hat over the coil-over hat or just put the strut top on?
  11. #326
    you coilover sets should come with a new coilover spring hat, which replaces the old one you just put you strut top on after that
  12. #327
    what he said.
    coilovers have a smaller diameter spring which the coil over kit wil have a hat to suit.
    with the std hat you will have issues of it hitting the body in the strut tower... where as the smaller diameter new hat will move around further giving way more adjustment posibilities.
    Black Betty >HERE!<
    (\__/)
  13. #328
    New guide written, contribute and add to as needed:
    http://www.toymods.net/forums/showth...992#post259992
  14. #329
    With the peugot hubs from the hilux/peugot/rona upgrade, when you replace the bearings, do you have the get the old cups pressed out and the new cups pressed back in? Or is it just a matter of hitting the old ones out enough with a hammer or something, and then just sliding the new ones straight back in...?
    Jase
    JZA023
  15. #330
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Smokey228
    Can tap the bearing cups in and out with a hamer and punch, clean the old grease out first as there is usualy a gap in the ledge bearings seat against that makes it easier to get a punch against it.
    regards
    jon
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
