Page 32 of 33 FirstFirst ... 2230313233 LastLast
Results 466 to 480 of 481
Thread: Celica Brake Upgrade
  1. #466
    Default Re: Celica Brake Upgrade
    Ha if I had $$ to spend I would but gotta try and make do with what I got.
    The easy way it would all work is a 12mm flat bar across the caliper bolted to the caliper mounts.
    A 17mm spacer that sits in between the caliper mounting points (butted up against the flat plate).
    Then this whole assembly bolts to the original caliper mounting points on the strut. So the bolts would go through the flat plate, through the spacer and into the original mounts.
    But then the question comes up about how strong it is and all. In my members ride thread it has been suggested the load might be too much as the caliper is now offset from the original mounting points.
    Though what I cant get my head around is that the caliper mounting point is still perfectly in line with the original mounting points on the strut, it's just that because the holes are inside of the caliper mounting points, you need the spacer to make up the thickness of the caliper mounting points.
    Probably sounds confusing!
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  2. #467
    Joel, having wandered around the paddock at the Noosa hillclimb recently, i think what you're proposing to do is commonly done in hillclimb specials and sprint cars... but with a solid chunk of alloy or steel.
    I'd suggest starting out with a thick slab and only mill down the areas where the caliper mounts sit
  3. #468
    Woohoo if I can find a DBA275 rotor (283mm diameter, 22mm thick, 27.5 total height) I can run a flat bracket on the RA28 strut. YES very excited. Can't beleive how perfect this rotor is for the RX7 caliper.
    Its also from a Peugeot 306 N5 series. Seems a bit rare as google turns not much up at all.
  4. #469
    I ordered the rotors this morning.. Will keep everyone posted with how it goes.
  5. #470
    if you have a bracket made up and it works id be really interested in a set
    thanks craig
    +rep for pioneering the rx7 caliper
  6. #471
    I have the big callipers with same size pistons not sure what there off,
    But i wanna know the channel seal size ID OD and width,
    You know the seal that goes in the fluid channel before you bolt the 2 caliper halves together
  7. #472
    Guys, just posted this in Takai's coilover/pug brake guide, but thought it was also appropriate here....
    Quote Originally Posted by sillycar chick
    Ive just gotten home from Aussie Auto and am a little perplexed as to why people are having trouble getting the DBA272 rotors. They made a phone call and said I can get vented AND SLOTTED rotors for $140 each Or I can get the RDA version (non slotted) for $60 each.
    So I dare say I'll be opting for the slotted DBA option and ordering them next week....
    Toyota Car Club (Qld)
  8. #473
    When i got quoted dba vs rda. The DBA was HEAPS more than the eqivilant(sp) RDA rotors.
    WTF?
  9. #474
    Cuzzo,
    Im not sure what you mean
    I was quoted:
    DBA slotted - $140 each rotor
    RDA nonslotted - $60 each rotor
    Therfore DBA were more expensive.
  10. #475
    Junior Member Backyard Mechanic scottsta22's Avatar
    You can get the RDA's slotted, I got mine from Lee's Performance Parts and they were much cheaper than the DBA's, just had to wait a week for them to be made up.
    http://www.performanceparts.com.au/
  11. #476
    Cuzzo,
    I was quoted:
    Slotted costs more than non-slotted. How much for DBA non-slotted?
  12. #477
    Quote Originally Posted by TurboRA28
    well I just bought home my rotor... hehe... well, i managed to stumble across the rotor which i believe will stop my car one day, suziki grand vitara, 310mm of stoppy goodness, and all for $25, though unfortunatly, will have to wait till i get back before i can test it
    oh well, definatly interested to see how your test fitting goes joel *thumbs up*
    '77 RA28LT #2 ← 2.2L 18RG...
  13. #478
    My RX7 upgrade is almost ready to rock n roll..
    http://toymods.net/forums/showthread...343#post360343
  14. #479
    Junior Member Grease Monkey 4SFED's Avatar
    Jan 2007
    Your on the right track by using the RX7 caliper - thats exactly what i did on the front of my TA22 although i used a set of Willwood 13" disks and Bendix Ultimate pads. A mate of mine did the machining for me and replicated the setup he used on the front of his club car - all up with brand new disks, reconditioned calipers, new pads and machining was under $1k. The results are nothing short of amazing. Stand on the brakes and it wants to send you through the windscreen - people are almost more impressed by the breaking on my car than the acceleration.
    I will get some pics of the conversion up on my site ASAP and post the link.
    4SFED Celica
    13B Turbo
    www.4sfed.com.au
  15. #480
    Anyone ordered pug disks recently in Brisbane? have got the struts and calipers (tho am still trying to find where-the-hell i left the 2nd XT130 hub) so i just need the disks and pads.
    I was going to try ABS out past jindalee and budget autoparts at oxley (becuase they're pretty good at ordering stuff in) for prices.
    cheers and tia,
    Charles.
    edit: Rang ABS at Mt Ommeny
    DBA272 - $153ea (unslotted), plenty of stock available in warehouse, retail price.
    Machining: $77/hour (approx 30mins per disk)
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
