Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 136
Thread: Toyota A series differentials (~1995 onwards) ratios? can i use G series crown/pinion
  1. #46
    Default Re: Toyota A series differentials (~1995 onwards) ratios? can i use G series crown/pinion
    what's a MZ10 ? - found it - it's a very old Soarer. No chance of Toyota having those gear sets available.
    Graham D
    Lexus RX350 (no mods yet !!!)
    Lexus IS200 / 2.5GT-T (1JZGTE VVTi + Getrag 6 Speed)
    Lexus IS200 (wife's car and no mods allowed !!!)
    Suzuki GSX750-F
  2. #47
    Mid 80s soarer. The diff C&P of an IS200 are the same as toyota IRS F series which were in MA61, MZ10, some RA65, some RT142...
    Lots of choice in ratios there
  3. #48
    Spent a day dpwn in Brisbane not long ago and went to all the diff shops in town. Nobody could source a ratio but all said it could be done if I found a set.
    Graham D
    Suzuki GSX750-F
  4. #49
    Well, there's lots floating around
    If you want an easy cross reference use the TRD LSD pricelist. Youre looking for cars that share a part number with SXE10 Altezza
    http://trdparts.jp/english/parts_lsd_mechanical.html
  5. #50
    teq Grease Monkey
    California
    ^ what he said. F-series 7.5" gear sets fit the IS200. The IS300 are all 8".
    You should be able to source a 3.42 or 3.58 gear set out of a 2wd toyota pickup F-series rear diff.
    I've confirmed fitment of the trd/kaaz/cusco/ats/ect. lsd's from the sxe10/gxe10 (is200 altezza) in the F-series diffs. The only difference is you need to use late model 'lsd' bearings that have a larger I.D. If you look at my post on my F-series diff swap in my AE86 I have the part #'s and info on it.
    Hey Ed,
    I forgot about this until just now, but I have my old 3.58's from the rear of my 8" 4x4 'hilux'/tacoma pickup rear diff in a box in the garage that I can take measurements on if you want to check it against your r&p.
    Andrew
  6. #51
    What is the chassis code for the IS300 (ie, 2JZ-GE Altezza)
    JCExxx?
    If so, the only pic i can find of the diff for one shows it in the same "small" housing as the 7.5" IS200
    You'd think if it was 8" internals they'd just use the Supra/Soarer/Aristo diff - why reinvent the wheel?
    edit: http://209.85.171.104/translate_c?hl...language_tools
    aha - Def 8", you guys are right on the money, the text says it is 8" unlike the other JZX/IS diffs in the similar housing
    Note though that some of those style of 'smaller' diffs have the 6-bolt axle stubs and some have only 4-bolt ones...
  7. #52
    The Celsior uses a different housing again, go figure.
  8. #53
    Quote Originally Posted by grahamd
    you may be mistaken the gearsets were probably common to later cars
    and i just got a 4.557 gearset new genuine toyota for a diff type which debuted in 1970
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
  9. #54
    ed: if you need definitive pics on the IS300 I can provide said pice/measurements from parents IS300, as MAtt linked to above. nfi on ratios
  10. #55
    Penrith BC
    is anyone able to collaborate the following information????
    According to the EPCD, the GS171 Crown Majesta came with an interchangeable 4.556:1 A series diff, C&P Part number is 41201-80015 if you wanted to check pricing with Toyota
    I looked at the available OEM A series ratios a few years back which covers 3.2:1 through to 4.556:1.
    GS171 is the same A series diff as JZA80/JZZ30/UZZ40 - I cross referenced the open diff centre part number from a UZZ40 to be sure... we bolt in UZZ40 and JZA80 centres and C&P in JZZ30 housings.
    Surely easier and cheaper than rigging up a G series cradle in there.
    ../delete/ban
    tech moderator
  11. #56
    Well according to the EPC, the 09/1999+ JZS177, UZS171, 173, 175 all have the same housing as the Supra/Soarer/Aristo
    The other 17x Crown models including the GS171 have what looks liek the smaller JZX/Altezza diff housing, however as the CWP appear to be interchangable they must also be 8" internals as the IS300 is....
    Now to get one - good luck
  12. #57
    Domestic Godess, NOT Domestic Engineer clubagreenie's Avatar
    From the look of that above correlated with my chat with a guy at toyota dealers spare parts help desk it would seem that anything starting with the same 41201 is compatable.
    Following is what I found out, still to cross ref supra part no's to other models.
    The above is available form Toyota Australia, $765- + GST.
    Fitted to
    RZF50 Qualis
    LN166
    167
    107 Hilux, 107 & 111 Australian models
    111
    205
    GS131
    151 Crown etc
    171
    Supra JZA80
    2JZGTE Auto
    Crownwheel and pinion Part No
    41201-80031 49-13 or 3.969:1
    2JZGE Auto
    41201-59175 49-12 or 4.083:1
    Note: Neither of these relate to the 6sp.
    Friends
  13. #58
    My understanding of Toyota part numbers is the first number (eg the 41201) just tells you what the part is, for example diff gear set, it alone cant be used to identify anything else about the part
    So i dont think you could assume compatibility from that number alone
    its the second bit of the part number that identifies the item
    Anyone care to verify this?
  14. #59
    It was just he that related it to compatibility, and that other gear sets from different models of the same car had different no's.
    fwiw 41201-80027 is the same ratio as 41201-59175 (jza80 auto non turbo, Lexus IS250)
    also found that 41201-80031 is JZA 80, Crown (??model) and Aristo (??model)
    Also gbox codes in the table:
    4FC is 4sp auto
    6F is 6 speed manual
    Friends
  15. #60
    Nah, AE86s for example clearly would not be compatible (live axle rear) but they have the same number...
    http://www.club4ag.com/faq_and_tech_...%20pinions.htm
    By The Witzl in forum FAQ
  2. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 01:58 PM
