Play in input shaft is normal
The end of the shaft will be supported by a spigot bearing which you should fit to the rear of the crank
I can get the torque setting tomorrow if you still need them
Also the clutch master cylinder is fed fluid by a hose joined to the brake master cylinder so the brake fluid and clutch fluid are in the same part
pos rep coming your way
