Since this has happened twice on a said good setup.
Please answer one question for me.
Was the engine dummy assembled by you or your machinist prior to machining/flycutting the pistons? both builds?
MAN, those valve reliefs are WAY to deep!
Cutting that deep and wide on the valve relief kills any ring land stability that piston ever had. Combustion stresses would deform that ring land area like an inbred retard, causing it to flex then break then it all turns to shit and the whole lot breaks away.
I think that really is a piss poor effort. It looks like he was intending you to use a 80mm intake valve or something. No offense.
I actually got away with taking SFA away from the valve reliefs when i built mine, I dialed in my cams with slightly wider lobe centers however.
This is stock piston
