Why not pick up off the 7mge ECU +B and trigger the Master Relay via the ECU M-REL pin. i.e. use as many of the factory existing wires as possible...Originally Posted by takai
I don't see any reason you can tap in +B inside the cabin off the existing 7mge ECU wires!
I would have thought that if you connect +B inside the cabin the engine bay +B would also be connected, have you checked the loom for to see if that is the case?Originally Posted by takai
I thought 2JZ-GE was the same as 2JZ-GTE in that the 40pin ECU plug was part of the body loom... but I haven't ever seen a complete 2JZ-GE with body loom!
By the way does the 2JZ-GE run a fuel pump ECU like the 2JZ-GTE? If so the FPC output from the ECU will be a PWM output and you will want an RC and FET circuit to drive the MX83 COR (Or a tachometric relay)...
Also you have to pull the DI pin on the ECU to voltage to get a PWM output on the FPC pin...otherwise the ECU thinks there is an issue with the Fuel Pump ECU
ps, not sure if I'm any help at all!
