Page 1 of 3 123 LastLast
Results 1 to 15 of 38
Thread: 2JZGE Wiring Diagram?
    Perth WA
    Default 2JZGE Wiring Diagram?
    I'm chasing an engine wiring diagram to suit a 2JZGE. This engine will be run using a factory ECU, part number 89661-14600, and is MAP sensored, not AFM (as so many diagrams show for USDM I've found). The ECU part number comes up as JZA80 Supra between the years of May 1995 to September 1997. The engine will also run the corresponding four speed auto behind it, so diagrams including any info on trans wiring are appreciated too?!
    practicing idiot Automotive Encyclopaedia sheepers's Avatar
    May 2006
    New Zealand
    Default Re: 2JZGE Wiring Diagram?
    i to would be very keen to get my hands on a diagram for this engine.
    i just bought one for my MS51.
    cheers,
    sheepers
    Perth WA
    Quote Originally Posted by sheepers
    cheers,
    sheepers
    Hmmm, sounds familiar?!
    http://toymods.net/forums/showthread.php?t=29465
    Well it's a 50 series crown with 2 doors!
    Aristo, but should be a fair bit closer than USA...
    Kudos to Madmont
    http://www.toymods.net/forums/showpo...8&postcount=97
    I only have the AFM type diagrams out of the US manual.
    Yeah, im chasing similar diagrams.
    Only my ECU is from a JZA80 Supra, and is MAP sensored.
    Madmont's diagrams are good, but all in Japanese...
    I would expect JDM JZA80 diagrams would be in japanese as well.
    Jealousy is a curse
    Yeah, as would i. Its just a pain.
    Perth WA
    unfortunately, thats also for AFM'd 2JZGE's - been there, seen that!
    Clint, if the loom is mostly intact surely you just need the power up wire colors? Tried Mos??
    Quote Originally Posted by Clintoris
    Surely 99% of the AFM and MAP wiring is the same, just the AFM/MAP 3 or 4 wires are different.
    Currently trying to identify where these plugs go:
    Which is especially fun seeing as i cant find the plugs on any of the diagrams i have. Including the wiring manual on mkiv.com (http://www.mkiv.com/manual/1995_elec...al/index.html), the 2jzge diagram which Madmont posted, and one on Supraforums.
    Anyone?
    Was my post from a year ago any help?
    http://toymods.net/forums/showthread.php?t=1298&page=3
    Jealousy is a curse
    Its a bit jumbled. Plus i think im using a later model loom to the one you posted.
    I found the correct wiring diagram, and put it here.
    http://gallery2.plebeians.net/v/cars...rical.pdf.html
    Here are the plugs from it:
    Im currently tracing the plugs, and most of the way through II1.
  1. 2jzge Vvt-i Wiring
    By teamdrinkalot in forum Tech and Conversions
    Last Post: 02-12-2008, 07:24 PM
  2. 4agte wiring
    By pro-16t in forum Tech and Conversions
    Last Post: 25-08-2007, 10:04 AM
  3. 2jzge eng wiring loom
    By gtz1 in forum Tech and Conversions
    Last Post: 26-11-2006, 08:58 AM
  4. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 11:27 AM
  5. 100kW 4AGE wiring diagrams
    Last Post: 15-04-2006, 06:03 PM
