Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Best way to stick anything to "PLASTIC"......??
    Default Re: Best way to stick anything to "PLASTIC"......??
    are you sure it is polypropylene? (the stuff used to make plastic bottles etc?) have you done a burn test?
    Plastic bottles are usually either HDPE (High Density Polyethylene, for milk bottles, resin ident number 2), or PET (Polyethylene Terephthalate, for Coke bottles etc, resin ident number 1)
    Penrith BC
    SIKAFLEX 252
    ../delete/ban
    tech moderator
    Hah, how did i know ed was going to say Sikaflex. Just like for fuel applications eh.
    Anyway, brackets and bolts ftw.
    Penrith BC
    not technically fuel application, more rubber grommet/alloy boss application, but i digress
    seriously, sikaflex >> owns all
    ../delete/ban
    tech moderator
    Quote Originally Posted by Hiro
    sorry, i wasn't talking about disposable bottles, i was talking about reusable lab grade polypropylene bottles....
    Jun 2007
    if so "The best joining method is hot air or nitrogen welding"
    Wasn't sure personally that is was PP as it had the >PP< tag on the Foam insert and front bumper, but I thoroughly checked it for any other markings.
    Okay, so pretty much a heat gun.
    Btw, are all cable ties PP ? Was looking at some I had and it had no markings on it......
    Which means I now have to go buy some but double check for the PP tag.... the guys at the store are going to wondering wtf ? Its a $2 item, some customers..... lol.
    it won't work.
    if you are joinging large items together of the same PP, then you use heat or N2 welding. but if you are attaching a metal bracket, bolts or screws and a second bracket behind are the only sure way.
    but.. go for gold, you know everything else
  8. #38
    Quote Originally Posted by abently
    Okay, now I've got a better idea of what I'm up against.
    Just checked, no its not ABS.... its PP (Polypropylene).
    merc-blue, what tip/method did you use with the soldering iron ? I tried that previously on some other part and it almost came up trumps, except I don't think I had the method down right to get the best result.
    The load will be equivalent to somewhere around 50+kgs of force.
    What the hell are you doing on your bumper? :S
    and how do you work out "50kgs" of force?
    Do you understand force and loading?
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
  1. Velco to stick a sub box to the floor
    Last Post: 04-05-2006, 03:44 PM
