Results 1 to 7 of 7
Thread: AE92 thermo fans not coming on
    Default AE92 thermo fans not coming on
    Hi guys,
    Picked up a Holden Nova/AE92 Corolla as a daily, but I've noticed that the thermo fans are not coming on.
    When I unplug the connector to the temperature switch, the failsafe kicks in and the fan starts.
    The car hasn't overheated yet, but the heater gets really hot sometimes inside the car.
    Does anyone know what the Tridon part number is for the sensor, and its on/off temp setting?
    I want to fit it at the same time as a new thermostat, so I can't pull it out right now to compare to the diagrams
    This is the catalog:
    http://www.toymods.net/forums/archiv...hp/t-5125.html
    Or is it normal for them not to come on in winter/cold weather?
    Thanks for any help
    244rwkw / 328hp @ 18psi
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    Default Re: AE92 thermo fans not coming on
    Got a temp sensor sitting in the Holden Nova I'm wrecking out front, if you want it I'll do it cheap.
    Mine takes plenty to get the thermofan to come on. I've got a full flow oil cooler setup so that helps, but my car will not get the fans on with ages at idle and the odd rev and hold, especially in this cooler weather. I wouldn't be rushing out and fixing stuff until you're sure you've got a problem; if they come on when you unplug it, and your water temp guage seems to behave normally and not get over middle of the guage, i'm not convinced you've got an issue.
    Has it had a new radiator or flush recently? It might just be efficient. Tried to make them come on? Let it get up to temp then hold it at 4k for a while? I would've thought if you let it idle stationary for 10 mins they'd come on...
    Toymods Club Member
    Cheers guys
    Just found out at Supercheap that it is a Tridon TFS150, approx $50. If it is normal for them to not come on often then I'll leave it til summer.
    Coolant doesn't look *too* bad, but I'm going to change it soon, along with the thermostat. Does it normally take a while for them to heat up? Maybe being a 1.6 they don't generate as much as my 1JZ cressy, and therefore take longer?
    After 5 mins idle they didn't come on, it was a cold night though...temp gauge was normal.
    Anyways I'm rambling, thanks for the advice guys, I'll keep an eye on it til the weather warms up
    Forum Sponsor Conversion King
    Quote Originally Posted by Ribfeast
    only if the current thermostat is stuck open.
    probly takes 5mins at idle to get warmed up normally but the fans dont kick in till 90 something degrees and with this cold weather that could take a while.
    the thermostat may be stuck open (or missing) and that would make it take a long time to warm up so that would be my first port of call.
    linden
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    It's commonly the switch that stuffs up. I know mine is stuffed because the failsafe kicks in when i unplug it but otherwise it doesn't work and i've replaced the fan with a spare that i know used to work.
    Should be ok in winter though so i wouldn't worry about it too much
    I have been pruned by old man river!!!!!
    those little 4As in the AE92s cool down sooo quickly.... i would side with GT here, its probably working fine but just hasnt reached the switching temp yet
    By The Witzl in forum FAQ
  2. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  3. How do you wire a light to signal thermo fans are on?
    By pisso001 in forum Tech and Conversions
    Last Post: 18-08-2007, 07:56 PM
  4. thermo fans. new TFS, having issues :(
    Last Post: 24-02-2007, 04:20 PM
  5. Thermo fans
    By Ghetto-AW11 in forum Tech and Conversions
    Last Post: 08-08-2006, 01:07 AM
