Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 111
Thread: JZA70 wont start...problem is very very wierd
    Default Re: JZA70 wont start...problem is very very wierd
    right finally got around to doing some more testing on this sucker yesterday
    have now confirmed that the ECU is farked, tried it on a mates car and it didnt work...have tried a known working ECU and the check engine light goes away but it still wont start, there is no spark to be seen at all.
    Fuel pump is pumping but there is no spark
    First things first a new ECU is needed, which I am working on getting...
    what else could possibly be farked though?
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    drunken escapades Conversion King fatboy13's Avatar
    Ignitor could be the cause of no spark...
    watching a bunch of supraforums members try to debate something technical is like watching a bunch of retards try to fuck a doorknob...
    tested another ignitor...same drama...
    didnt pull simons off to test on another car but im assuming its working...because I tested a known working ignitor on it with a known working ecu and same issue occurred
    Check the caps in the ECU before you bin it.
    "Cranks, fires, and dies immediately" The poor old ECU has no idea what is going on either not receiving signal from TPS, or AFM if you have one.
    cheers Chuck.
    MS51Crown Coupe,
    ive put the ecu in my mates car and tried to fire it over...it does not work
    Quote Originally Posted by ChuckLandwehr
    cheers Chuck.
    so you think the TPS could be fubar?
    the ecu is definitiely farked...I just cant belive that 2 things have become broken at the same time
    Nay, check the caps. If they are leaking then it is concievable that it has provided a nice power surge down a line that didnt like it at the same time as it died. I.e. it could fry circuitry in the MAP or TPS.
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Dec 2006
    ^^^ hrmmm good thinking there.
    We should have tried my MAP sensor aswell Matt.
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    Quote Originally Posted by Hengsta
    hmmmm
    you able to come back around tonight?
    I have spare Map sensor here...dont have spare TPS though...
    actually dont bother coming round tonight...wait untill I get a TPS...
    Dec 2006
    LOL yeah i will... not come around ahah
    lol
    ok then...so ive got to try another map sensor and another TPS...
    Is there spark at all... if its not ignitor or ecu, then what else regulates when it should fire?
    CAS?
    no spark at all
    please god dont let it be the CAS
    fucker of a job
    does the car have "kustom" wiring?.. missing a relay to take load off the ECU etc?
  1. Bigport 4AGZE Cold Start Issue and Flat Spot
    By sbyder in forum Tech and Conversions
    Last Post: 12-05-2008, 08:01 PM
  2. 7MGT-E Problem
    By 55Supra in forum Tech and Conversions
    Last Post: 19-04-2007, 01:31 PM
  3. JZZ30 Loom Vs JZA70 Loom
    Last Post: 12-04-2007, 04:33 PM
  4. Common Problem AE71/KE70 (Now with pics) Headlight/indicator Switch
    By stahlz_ae86 in forum Tech and Conversions
    Last Post: 18-07-2006, 05:13 PM
  5. Electrical Problem
    By AutoXCelica in forum Tech and Conversions
    Last Post: 15-01-2006, 02:32 PM
