Results 1 to 15 of 24
Thread: 4ag big port small port
    May 2006
    Selangor
    Default 4ag big port small port
    Hi all, just wanted to know...besides the difference in port sizes between the two what are the big obstacles preventing the small port intake manifold mounting onto the big port head? Bolt spacing different? Manifold hitting engine parts? Port/cylinder spacing different?
    oregon
    Default Re: 4ag big port small port
    the port shape... bolting a large port manifold on to a small port head will give you SUBSTANTIAL eddy points all around the joint. It CAN'T be done without some type of adapter......
    May 2006
    Selangor
    is the bolt spacing on both the manifold totally the same?
    Smallport manifold runs 4 runners whereas the bigport manifold has 8.
    Why dont you just get a bigport manifold?
    Hoppers Crossing
    see here
    thats the TVIS sitting on the smallport head. no chance
    the bolt holes are in the correct positions though.
    May 2006
    Selangor
    ahh Grega thanks for the great pic postup needed that, +rep points posted by any chance would you be able to provide me with the small port width and lenght measurements?
    May 2006
    Selangor
    thanks for the post, no I dun need to go back to carbs, it's just that I need to know why it's not possible to use either one of the manifolds over the other.
    Hoppers Crossing
    it was kinda a funny pic i never meant to take it on purpose, just did because i know the question gets asked a fair bit ; the original is here in my ta22 thread
    http://www.toymods.net/forums/showthread.php?t=23450
    i'll measure that stuff up for you no problems. prolly tonite after work.
    G
    This is what you need, or need to produce.
    Available from: http://www.technotoytuning.com/productdetail.php?p=374 or probably producable locally. Depends on how much your time is worth.
    Hoppers Crossing
    pretty cheap too for $99USD...
    oregon
    Muhahahahahahaha... you've found a KaiPower Port reducer!!! nice find!!! (Item in bottom of photo...)
    Used on large ports to narrow the port and improve port velocity.....
    yah looks neat.. bit pricey for the setup tho, but does include a head and manifold (without the ghey bend for brake booster)
    Hoppers Crossing
    the small port port size is 32mm high and 52mm wide
    May 2006
    Selangor
    Quote Originally Posted by Grega
    great!! thanks again for your help
  1. Small port dizzy to CAS and multi-coil ignition?
    By HRV-00S in forum Tech and Conversions
    Last Post: 17-03-2008, 05:47 PM
  2. 4AGE small port --> making the ports smaller again
    By 92-GTI in forum Tech and Conversions
    Last Post: 09-03-2006, 03:51 PM
