Results 1 to 11 of 11
Thread: 7mge alternator amp upgrade? 90-100amp?
    Default 7mge alternator amp upgrade? 90-100amp?
    Hi there.
    I need a 90-100 amp alternator for 7mge. Currently using a 80amp.
    1uz has 4mm difference from pivot to adjust point, also has different plug. is 100amp tho
    What are the amp ratings of 1g-gte and 7mgte alternators?? Are these a direct swap?
    Any suggestions?
    Junior Member Domestic Engineer 1200det's Avatar
    Default Re: 7mge alternator amp upgrade? 90-100amp?
    The 7MGTE is still an 80amp alternator
    Direct upgrade is the SW20 Turbo alternator you just need to swap your pulley over from the 7M.
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    Have you got a definant amp rating for that?
    My current alternato apparently has a bolt spacing of 160mm. The net tells me that sw20 alternators are 165mm spacings. So probly not quite as "direct swap" as we thought. Or am i wrong?
    Cheers.
    Just did some searching and this is what i found.
    However my 7mge part number matches a 160mm bolt spacing alternator weird.
    Brand New Alternator OEM NO 100211-100,
    12V, 70A, Internally regulated, 5PV Pulley
    Different plug with Bosch type alternator, Need adaptor.
    Replace Ingram RXA400
    Suit: Holden Apollo JK eng.3S-FC 2.0L 89-91;
    Apollo JL eng.3S-FE 2.0L 91-93;
    Toyota Camry eng.2S-E 2.0L 83-87;
    Camry eng.1S 1.8L 87-89;
    Camry eng.3S-FE 2.0L 87-93;
    Camry eng.3S-FC 2.0L 89-91;
    Celica ST eng.3S-FE 2.0L 86-89;
    Celica GT-4 4WD Turbo eng.3S-GTE 2.0L 90-92;
    Celica ST184 eng.5S-FE 2.2L 89-94;
    Celica ST204 eng.5S-FE 2.2L 94-98;
    Celica SX eng.3S-GE 2.0L 86-89;
    Corolla Twin Can eng.4A-GE 1.6L 86-89;
    Corolla SX & GTi eng.4A-GE 1.6L 89-92;
    MR2 Hardtop eng.4A-GEL 1.6L 87-95;
    MR2 Hardtop eng.3S-GE 2.0L 90-98;
    MR2 Hardtop Bathurst eng.3S-GE 2.0L 94-99;
    MR2 Hardtop GT eng.3S-GE 2.0L 94-99;
    Supar eng.7M-GE 3.0L 86-90;
    Supar eng.7M-GTE 3.0L 89-93;
    RAV4 eng.3S-FE 2.0L 94-98;
    RAV4 eng.3S-FE 2.0L 98-00;
    vic
    MZ21 GT soarer alt is 100 amps but they will supply 110 amps . i use one on my 4WD to help with the winch. Now i should try to sell you one hehe
    Dave
    sell me one!
    I ventured into ashdown ingram today, They try to tell me that my alternator is a 170mm spacings which contradicts the 165mm i found in another catologue and also the 160mm a 7mge is suppose to have......... F*cked if i know whats right or wrong here.
    Best way to find out is pull the f_cker off i spose.
    Modify is my middle name Grease Monkey Darola's Avatar
    hey there mate...
    i have a high output alternater.. 130amp if interested
    Ed
    Eddie 0433 85 69 66
    denso? Whats the part number?
    vic
    The larger output ones have a wider bolt spacing .
    $100 for one.
    Dave
    Just fitted a 130amp sourced from forum member Darola.
    Problem is solved. I tested it with windscreen wipers, washers, air con fan, heater fan, cd player, high beams, brakes and blinkers all on and engine does not miss a beat when doing low revs.
    Thanks for assistance
  1. Hoppers Stoppers brake upgrade vs Pug/Lux/Corona brake upgrade
    By ThaNav in forum Tech and Conversions
    Last Post: 04-10-2007, 12:31 PM
  2. 4A Power Steering Pump Upgrade
    Last Post: 23-01-2007, 10:16 AM
