Results 16 to 21 of 21
Thread: 18R rattle
    Default Re: 18R rattle
    i had a 22re in a corona same basic series of motor, had the timing chain rattle as the guide had warn all the way through. $10 says its your chain guide.
    RA23 - Twincharged
    JZZ20 - Daily
    Definintely timing chain rattle. Common as bums on humans.
    Now - RA23-WRX
    Apr 2008
    Cheers guys i might give it a crack this weekend if i can get my manifolds on my ST141 to drive that around
    Chances of you tearing the head gasket are high. Make sure you have plenty of sealant, threebond red sealant is the way to go best by far. Take your time doing it and all will go well.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    Apr 2008
    Well i finally found my gregorys car manual and now i am 100% confused. Here is what the gregorys book says about removing the timing chains:
    1)Remove engine
    2)Remove cylinder head
    3)Remove water pump
    4)Hold flywheel/drive plate against rotation, loosen and remove the crankshaft pulley bolt and washer
    5) Remove crankshaft pulley from crankshaft
    6)Remove the sump
    7)Remove the oil pump
    8)Remove the timing case,discard gasket
    9)Remove outer timing chain from the outer auxilary drive shaft sprocket
    10)Remove lower chain tensioner
    11)Hold flywheel again and remove auxilary driveshaft sprocket retaining bolt and washer
    12)Remove the outer auxiliary drive shaft sprocket
    13)Simultaneously remove the crankshaft sprocket, inner auxilery driveshaft sprocket and timing chain.
    14)Remove the upper and lower timing chain guides
    15)Remove fuel pump and dizzy
    16) Remove auxiliary drive shaft and thrust plate.
    Do i realy have to take the engine out, split the engine n trans?Has anyone got any simpler ways to do this would be much appreciated.
    Yeah, you can do it without pulling the engine out.
    Just remove everything forward of the engine (rad, grill, bumper, etc) to give yourself more room to work.
  1. What is that rattle?!
    By WA_TRD_83 in forum Tech and Conversions
    Last Post: 19-05-2008, 11:30 AM
  2. 18r piston question
    By quikestsilva in forum Tech and Conversions
    Last Post: 20-06-2007, 05:51 PM
  3. 2TG head/ 18R block
    Last Post: 08-06-2007, 01:36 PM
