Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 105
Thread: 4AG headwork, now block too
    Hoppers Crossing
    Default Re: 4AG headwork
    this is all cool
    has anyone noticed though how much the actual chamber shape has changed?
    in 30psi' case if you're cramming 30psi in there its probably not so much of an issue, but, in the case of a NA motor i'd hazard at a guess it would make a difference somewhat.
    sam's head pic shows the piece in between the valves which kinda comes down a fit bit between them, but, in the original pic (and 30psi' pic) this has been removed completely
    any thoughts? i'm about to put my head on my 4AGE bigport/7 rib combo this weekend so really value any thoughts and opinions here
    thanks guys
    Hoppers Crossing
    actually sam's pic is not a 4AG head. i think.
    i just had a look @ my small port head and it looks similar to 30psi's
    yeah I should of said so if I didnt, its a 7afe head, which putting your description in my words is that the 7afe heads have a significantly larger squish area than any 4age based head.
    7afe had economy in mind when they designed it? 4ag had more performance in mind?
    perhaps barely...
    current "economy" motors have more performance than older performance motors
    I am talking about "had" sorry. lol
    Hoppers Crossing
    current economy motors also have worse economy than they did previously too
    (the 100kw 1.8 litre celica (only a couple of years old) i had to chuckle about when they were advertising 100 killer watts....ooooh you had that back in the late eighties well done
    now back on topic...
    thanks sam.....i wondered what it was from.
  8. #38
    Quote Originally Posted by jeffro ra28
    hmm its really tricky knowing if the increased squish area helps it or retards it in power. I believe some deshrouding is needed and amoung many things I am using motorbike heads as a reference in my quest for making a hybrid screamer.
    grega: no problem. With the economy thing though could it just be from the massive increase in weight small cars have copped over the years?
  9. #39
    Tallahassee, FL USofA
    Just geussing, but i think the reasoning behind leaving the cast finish in the chamber is because it has more surface area then the polished surface. Can only guess as to why they want more surrface area. Perhaps heat dissapation or insulation?
    With the flow of one valve hitting the others flow in the center of the chamber, there isn't much that can be done that would make a difference, compared to working on that solid wall that partially surrounds each one.
    I'm guessing that a rougher surface has more surface area and conducts more heat whether covered/insulated by carbon or not, and that I don't want to put more heat into the head around the exhaust valves, cool & reduce the combustion pressure of the power stroke and put more heat into the cooling system.
  10. #40
    that makes sence but it all sounds like something that would never have any real world effect. Perhaps they just leave it because they know it wont do shit all either way?
  11. #41
    oregon
    Quote Originally Posted by Grega
    this is all cool
    thanks guys
    As I said... the cost to do my head was less than .75cc, or about 2%.
  12. #42
    Chiba
    Hmm, I have a spare bigport head laying around here. I'll have to get it crack tested etc, then try some of this stuff out....
  13. #43
    oregon
    Iv seen one off specially developed cylinder heads worth 40k a pair. They had smooth chambers all round!
    Do you think perhaps we have a certain misinterpritation of the japanese language in that TRD guide?
    Hmmmm, a photo of OEM 9.4 to 1 piston(on the left), and OEM 10 to 1 piston....
    more surface area??? better heat dissipation?
  14. #44
    California
    There maybe a couple reasons why they (TRD) polish a certain part of the chamber. Here's how I see it. They remove minimal material from the chamber to achieve the highest allowable CR as per FISA rules and, this is for N2. If they remove more, chamber volume will be increased, thus lowering the CR.
    Now for GROUP A, 10.8 cr for rally (36.5 cc/chamber) and 11.8 cr for race (33 cc/chamber).
    Or maybe, this is a FISA restriction and they are only allowed to touch those areas on the chamber. I think it's all about the rules. My two cents.
  15. #45
    May 2007
    Should reshaping the combustion chambers/removing material be left to the pro's or can a novice have a decent hack at it with relatively good results?
    Slightly off topic, but ive got my 3rz apart at the moment, and considering im chucking in a 3mm headgasket, im thinking of removing the quench areas totally (from my little knowledge they will just add to detonation when using a big headgasket). and wanted to know if i should give it a shot.
    Ill post a picture up tomorrow showing the chambers, and you guys can tell me what i should be removing (ive got a spare anyway so if i make a mistake im still ok).
    Also ive attached a pic of supercrowns DIY head (hope he doesnt mind), it seems he has too totally removed the quench zones with good success (am i seeing wrong?). Discussion?
  1. 4ag into ma70 chassis
    By mdcmotorsports in forum Tech and Conversions
    Last Post: 01-12-2007, 01:02 PM
  2. 4ag sprinter
    By Wedged'86 in forum Tech and Conversions
    Last Post: 15-11-2006, 08:13 PM
