Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 105
Thread: 4AG headwork, now block too
    perth
    Default Re: 4AG headwork
    ahh it means must where "goggles"
    i bought a pack of undies in bali and on the intructions (becuase i forget how they work) they said "do not tumble fry" i thought it was funny.
    theres very little shrouding on the 20V engines so you would be lucky to get anything out of it even on a flowbench.
    heres how I was thinking of doing my chamber initually:
    not quite the same thing as the 4ag drawing posted earlier but instead a general deshrouding. I believe one of the thoeries is from the valve to the chamber is 85% of the valve lift and 65% for the exhuast. Quoted from the four stroke tuning guide.
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    Very nice! That's the next step left on my 16v Probably do it in a few months.
    Anyone willing? hehe
    I have been pruned by old man river!!!!!
    top left says
    の範囲で滑ら
    makes somethings area slippery?
    top right is too small to read
    btw, there are no joggles in japanese... in english it measn "dowels" ? (bits sticking out?)
    Careful, you don't want to take too much out of your quench area.
    oregon
    Hahahahahahahaha...... you guys are all engineers... not an artist amoung you!
    joggles means the drawn lines! OR look at the photo and the lined section should be removed and polished!
    Sam.... I'd talk to Bill.... I'm NOT sure you want to remove that much squish area. I was as careful as I could be and I didn't remove any squish area....
    Giving it a brief look....
    The areas with less yellow dots... should be gradually tapered, maybe with a very tiny 1/4 round used on the edge (to try to avoid a high temp spot), the areas showing more yellow dots(areas outlined in purple) are areas I'd "adjust" in the combustion chamber.
    Concerning what to polish on a "F" head..... I don't know..... I didn't have to know on the "G" head... someone, likely an engineer, told me what to do... I just had to follow it
    S.A
    While we are on topic of de-shrouding and combustion chambers.......
    Here's a pic of the ones i did on my 4a
    ben: your right, see my comment below:
    oldeskewltoy: even though my research said to do so I was told not to take too much out and I didnt. I ended up doing something very close to what you drew. A little more will be taken out but not too much.
    oregon
    30psi 4agte - You're running 30 psi(or so I assume...) a completely polished combustion chamber allows for no area to get warmer then others... I ASSUME that the TRD porting diagram was developed for N1, or group 2 race engines.... all being N/A. I BELIEVE the reason TRD leaves the center dimpled is to allow the center of the CC to retain more heat then the sides of the CC
    Btw... VERY pretty head....
    I've been giving some thought to making desktop toys... one section of a head, one cylinder... fully polished (like yours) with valves fitted... using 2# springs. That way the person can pick it up and play with it while on the phone... or doing some other mundane task....
    S.A
    hmmmm do i detect some sarcasim ?
    Question: why do you want one area of the head to get hotter than another ? I would think you would want a even spread of heat to deterr detonation from hot spots.
    All the pics i have seen of formula atlantic heads have had smooth chambers........ come to think of it any decent head i have seen has had smooth chambers
    oregon
    Quote Originally Posted by 30psi 4agte
    No sarcasm.... hard work is hard work!
    I did as the TRD manual pictured.... Hmmm I wonder if the reasoning behind it all is the center of the chanbers don't require it.. while the outer edges do, and the TRD manual is showing the way to get the most for the least change. If I'm not mistaken chamber volume must be within -2% and +4%, for one of the racing series......
    Like forced induction, Formula Atlantic is a highly specialized head... I was to Arnie Loyning's shop here in Portland Oregon USA. Loyning has made some of the winning Formula Atlantic engines.
    http://www.loynings.com/
    I know what a finished F/A head looks like he has a number of them along with F/A cranks... and all sorts of goodies!
    Just geussing, but i think the reasoning behind leaving the cast finish in the chamber is because it has more surface area then the polished surface. Can only guess as to why they want more surrface area. Perhaps heat dissapation or insulation?
    Iv seen one off specially developed cylinder heads worth 40k a pair. They had smooth chambers all round!
    Do you think perhaps we have a certain misinterpritation of the japanese language in that TRD guide?
    Could it be because the racing series used stock pistons and they didn't want to lower compression any more than they needed to?
    ^ That would be a more likely reason. It's a trade off between compression ratio and combustion efficiency.
    The problem with all of this is that there is no reasoning for doing only that section so we are left to guess why.
  1. 4ag into ma70 chassis
    By mdcmotorsports in forum Tech and Conversions
    Last Post: 01-12-2007, 01:02 PM
  2. 4ag sprinter
    By Wedged'86 in forum Tech and Conversions
    Last Post: 15-11-2006, 08:13 PM
