Page 7 of 7 FirstFirst ... 567
Results 91 to 105 of 105
Thread: 4AG headwork, now block too
  1. #91
    SC14 7AGZE Grease Monkey
    Jun 2007
    FL
    Default Re: 4AG headwork, now block too
    To clarify, I was talking about a stock 16v largeport bluetop engine. It comes with 115hp 100ft/lbs stock... which minus 17% drivetrain loss would equate to 95rwhp 83ft/lbs. To claim a 40hp & 20 ft/lbs gain to 135rwhp 103ft/lbs by just a standalone and cams (no intake manifold, no ITBs, no porting, and keeping all emissions equipment) is far fetched on a 1.6L Naturally Aspirated engine. Thats all I was saying.
    Not a smallport, not a custom intake manifold or ITB'ed engine or full out race engine with no emissions equipment, not a Holden V8........ a stock bluetop 4A-GE. Yes, 40/20 gain is working magic.
    SC14 7AGZE build: http://beasted86.webs.com/
  2. #92
    Quote Originally Posted by turbo4agte
    Not at all. See here:
    Quote Originally Posted by Schmitt
    Slightly off topic.
    FWIW my completely standard bigport 4a with just a microtech ecu made 107hp at the wheels. And that has also been confirmed on four different dynos, 1 of which was at the dyno day at SAS. It was also down on compression. So with a decent condition motor and a set of
    30rwhp out of a cam is NOT unreasonable.
  3. #93
    oregon
    Camshafts have been chosen!
    226 degree @ .050" lift
    lift to be 8.38mm
    centers @112 degrees
  4. #94
    whats that translate to in jap "bigger" duration?
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
  5. #95
    oregon
    Quote Originally Posted by roadsailing
    264 type... cam timing is nearly stock at 112, many other 264 type cams use 105 as the cam center, this lowers DCR by 2/10s. my DCR is 9.67. Using anyone elses 264 would make my DCR 9.93. My variables are below.
    bore: 3.208
    stroke: 3.031
    rod: 4.803
    static CR: 10.7 to 1
    with my goals, I decided to trade some DCR for a bit of lift.
  6. #96
    oregon
    This is her first dyno run. The initial map was only written to 7500 rpm(engine and cams are good to 8500)
    141whp @ 7468, 108#s wheel torque @ 6127rpm.
    Engine numbers(back calculated by their dyno) 164hp @7468, 128ft/# 6127rpm.
    Numbers very close to and in some cases exceeding blacktops. This is also her first pull, the new ECU is barely talking at this stage(I still can't get idle under 1500 in closed loop) I expect peak hp to exceed 150whp, and I expect peak torque to exceed 110#/ft also measured @ the wheels
  7. #97
    Low rep Grease Monkey
  8. #98
    [IMG]<a href="http://s704.photobucket.com/albums/ww49/pornstr20v/?action=view&current=31102009343.jpg" target="_blank"><img src="http://i704.photobucket.com/albums/ww49/pornstr20v/th_31102009343.jpg" border="0" alt="Photobucket" ></a>[/IMG]
    [IMG]<a href="http://s704.photobucket.com/albums/ww49/pornstr20v/?action=view&current=31102009345.jpg" target="_blank"><img src="http://i704.photobucket.com/albums/ww49/pornstr20v/th_31102009345.jpg" border="0" alt="Photobucket" ></a>[/IMG]
    [IMG]<a href="http://s704.photobucket.com/albums/ww49/pornstr20v/?action=view&current=31102009349.jpg" target="_blank"><img src="http://i704.photobucket.com/albums/ww49/pornstr20v/th_31102009349.jpg" border="0" alt="Photobucket" ></a>[/IMG]
  9. #99
    sorry abt that guys
  10. #100
    Junior Member Grease Monkey markiitourerv's Avatar
    south australia
    umm, yeah ok, and this is relevant because....
  11. #101
    oregon
    Now THAT is emissions complaint....... SWEEEEET
  12. #102
    Hoppers Crossing
    do you guys have to do this every 6 months?
  13. #103
    oregon
    hahahahaha... no... the certificate is good for 6 months... note there isn't a plate.
  14. #104
    Hoppers Crossing
    ok i get it. we only have to 'roadworthy' our cars here once here in VIC and thats it - its valid for the life of the car - example my 1966 XP had its roadworthy in 1968 when my father bought it. technically it is still roadworthy - although its about eleventy billion miles from it.
  15. #105
    oregon
    thought I'd add an update to this...
    The tune back then was still pretty bad.... it had a vacuum leak (using an AFM T/B instead of a MAP T/B you'll get that leak....) and a ignition map that was mostly undone, call it a break in tune only
    this ignition map goes with the dyno run previously posted
    a 2nd dyno run was done last year, around this time (Feb 2010) and she planted a bit more power
    That ignition map was a bit more complete, but it also was a bit conservative
    The ignition map has since changed....
    To reflect real world use, and is now far more complete, and a bit more aggressive. There is no new dyno to show the improvements, but I do have 3 passes @ the local drag strip that tells some interesting information......
    The short version.... she ran 15.77 @ 88.8 mph. Dig a bit further though and you see a car that NEEDS a better driver - the best reaction time I could muster was .716
    my horrible 60 foot times, as compared to the overall run show that a better driver can likely make my car do passes in the sub 15 second range, and she should break out above 90 mph.
    Not too bad for an emissions compliant 1606cc 4AGE, T50, and 3.90 open final drive.
  1. 4ag into ma70 chassis
    By mdcmotorsports in forum Tech and Conversions
    Last Post: 01-12-2007, 01:02 PM
  2. 4ag sprinter
    By Wedged'86 in forum Tech and Conversions
    Last Post: 15-11-2006, 08:13 PM
