Results 1 to 7 of 7
Thread: Stoked with 20v issues
    Apr 2008
    Default Stoked with 20v issues
    My 20v rolla has been driving my head in. Engine has been replaced recently cause old one was giving me issues.
    Symtons
    - Wont start first go, especially on cold. Has to be kick started like a carby,
    - idles rough when engine light turns on.
    I've replaced o2 sensor, motor/exhaust sounds better but still runs rough.
    What could it be?
    - ecu?
    - afm?
    Have not performed diangnosis before, but will try. For now through me some ideas till I diagnose.
    Junior Member Backyard Mechanic KARNAGE's Avatar
    Default Re: Stoked with 20v issues
    Is it a aftermarket ecu? if so it could be the cold start is not set up i had the same problem with my 20 valve when i first had it going. Does it only run rough on start up and then it goes back to normal when its at operation temp?
    Apr 2008
    Nah factory ecu.
    Runs rough randomly. I used to think it was rough only when cold but now it odes it when ever.
    i am a Backyard Mechanic WiLo's Avatar
    Quote Originally Posted by lostie
    have you checked error codes?
    milk and juice come in 2L, The cheapest wines come in 5L, the finest vodka comes in 1L
    Leaking capacitors in ECU?
    I agree with wilo though - pull codes and then work from there.
    Hoppers Crossing
    check your grounds on your engine. ensure that all grounds are clean and secure since you put the replacement motor in - you may have forgotten one / its loose.
    Apr 2008
    have checked codes. geting: normal operation (no-malfunction)
    What next? get ecu tested?
  1. Alternator/Charging issues.
    By DoctorDubb in forum Tech and Conversions
    Last Post: 07-03-2008, 04:44 PM
  2. 1G-GTE hilux - running issues
    By THREAT in forum Tech and Conversions
    Last Post: 12-06-2007, 11:03 AM
  3. removing driveshaft issues
    By 4agte in forum Tech and Conversions
    Last Post: 27-02-2007, 08:50 AM
  4. GZE Aftermarket comp issues
    By craigy in forum Tech and Conversions
    Last Post: 17-01-2006, 09:45 PM
