Results 46 to 60 of 66
Thread: 1JZ GTE 100K service
  1. #46
    Default Re: 1JZ GTE 100K service
    pully the same?
    Malicious
  2. #47
    south australia
    pulley goes over the end of the water pump snout yes?
    i can only give you dimensions of the pump itself as i haven't pulled the engine apart yet to do the timing (94000KMS and counting).
  3. #48
    Yeah the big wheel that the belt goes round! More wondering the HOW the pully bolts onto the pump, bolt pattern or whatever...
    Yeah I'm in the same boat, pump on car waiting, pully/belt ect on the book self just trying to find out if i need a 2jz-gte water pump to suit the pully! Wilbo has told me that they are different but if you guys are fitting the whole pump and it doesn't come with a pully then I'm guessing they pullies (and pumps!) must be interchangable...
    Malicious
  4. #49
    http://homepage.ntlworld.com/noctilu...s/0070e5b5.gif
    Looks the same as the 2jz-gte pully I have, sweet.
    Malicious
  5. #50
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    hey does anyone know the part number for the cam cover seals?
  6. #51
    south australia
    ummm that's not the part number that is on the front page is it? (camshaft seals x2)
  7. #52
    Junior Member Grease Monkey EvilJack's Avatar
    State
    Quote Originally Posted by NeoNasty
    1jzgte and 2jzgte waterpump = the same.
    this is incorrect
    if your running a hydro water pump it is different AND the pulley is different
    non hyrdo (2jz pump and also found on some 1jz's) on the left and hyrdo on the right in the link below
    the pump on the left uses a pulley that has 4 bolt holes and the pump on the right uses a pulley that has 1 bolt hole
    the non hyrdo pump you can get for $120-130 trade from toyota but the pulley is around $300 or somthing ridiculous so either find one second hand or get one made up
  8. #53
    cam cover seal <> cam seals.
  9. #54
    south australia
    maybe a better statement would be to see what sort of pump you are running first by a simple inspection because i was 100% certified by toyota that my water pump at home that it says is a 2jzgte water pump will definately fit on the 1jzgte.
    ps my pump is the one on the left in the picture for a 2jzgte.
  10. #55
    Junior Member Domestic Engineer NeoNasty's Avatar
    eep. well Evil Jack that does make it more interesting.
    I have the one on the left. if you haev the one on the left.. then 1jz = 2jz otherwise.. well screwed if I know. Im not a 1j guru just going off my own experiences.
    HZJ75, RS41, JZZ30
  11. #56
    south australia
    ok shamelessly stolen from soarer central
    "I've now confirmed that the parts for jzx90's and TT soarers are definitely different (my part number is 16110-46011). I can order this part without the hydraulic assembly but it is still three times the price of the soarer pump"
    the internet also tells me something of JZA70 model supra's having this hydraulic water pump setup also.
    It also mentions that you could swap over to the cheaper soarer/jza80 style water pump but will need to find or fabricate a pulley for it. (as EvilJack mentions).
    so a mixed bag
    1jzgte pumps should be the same as 2jzgte pumps...unless you have the hydraulic water pump style 1jzgte. these are found on jzx90 chasers and possibly jza70 supras.
    if you have the hydraulic type, apparently you should convert to the non hydraulic/cheaper type to save you financial heartache..
  12. #57
    State
    i recently converted from the ol hydro 1jz pump and the 2jz pump goes on without a hitch
    very worthwhile doing for the price
  13. #58
    AU
    Guys I am doing a 100k service (2nd one for the engine) soon for my car with the help of Barned01 (original poster)
    We checked last night, the JZA70 Supra had a hydro water pump . His girlfriends Soarer has the 2JZ style water pump (checked both last night).
    The Supra is a 1990 version, so maybe they changed it in the later JZA70's I don't know.
    Anyway damn it!
    For whoever has changed from the hydro setup, what is involved?, and what thermo fan did you use in the place of the hydro fan?
    I am hoping I dont have to change it (prev owner may have done it - awaiting confirmation), but if I do need to replace it I don't want to buy a new hydro one due to the stupid cost involved.
  14. #59
    Holy sweet bajezus. Just got off the phone with toyota. A new hydro 1jz water pump is $1500.00!!!!!! yes the decimal point is in the right spot!!! I'm thining about leaving the current one on there untile i have problems then stress about thermo replacement fans...
    Malicious
  15. #60
    AU
    Quote Originally Posted by ReQuieM
    LOL wtf.
    Umm ok, if mine is in need of a replacement then I think the 2JZ one is a given
    2JZ pump
    Billet pulley
    Twin 12" Thermo's
  1. 1jz vs 2jz heads
  2. 1JZ into EA Falcon
    By bezza05 in forum Tech and Conversions
    Last Post: 27-01-2006, 10:18 PM
  3. Upgrading 1JZ alternator
    By beasht in forum Tech and Conversions
    Last Post: 19-01-2006, 08:28 PM
