Results 16 to 30 of 66
Thread: 1JZ GTE 100K service
    Default Re: 1JZ GTE 100K service
    tensioner assy being timing belt tensioner...
    how did you get away without a accessory belt tensioner?
    Here is a cheaper alternative for the idler pully, especially if you have the plastic type
    Toyota plastic pulley & bearing
    OD 96mm
    ID 17mm (bearing)
    width 26mm
    Ford Windsor 5lt Part No EP060
    OD 100mm
    ID 17mm
    width 30mm
    The Ford Windor 5ltr pulley is metal and the bearing is easily replaced, fitts perfectly, not clearance issues with anything, it was only about $56 from the local repco, but that may have been staff rates. hope that helps
    Rogue-VL
    rogue: nah thats retail staff price is around half that.. - for the windsor part.. there's also a jeep one thats a bit smaller.. - this is the pulley i used as i dont have air con or power steer
    dont change your auto fluid, just get the auto serviced, so it can be adjusted, its only like $120 to get it done, compared to $60 for the oil/filter
    The boobs are back
    DOHC: what do they actually adjust?
    the bands, they tighten up around the drums which engage the gears
    http://auto.howstuffworks.com/automa...ansmission.htm
    The boobs are back
    There are bands in Toyota's electronic transmissions?
    there isnt??????
    The boobs are back
    I can confirm the part # for the timing belt is correct, and the part number for the timing belt tensioner is 1350546020.
    south australia
    I'm still about 2 months away from ordering parts so sorry i can't confirm just yet.
    I will add the part number you have there for the timing belt tensioner however.
    Are you happy to wait?
    or ring penrith toyota, they seem to have a good grasp on all things 1jz
    ? i dont care.. i was just letting you know what the part numbers are these are the correct parts, because they are on the invoice i have for the parts that fitted
    south australia
    ha i just re-read your post and noticed the "i can confirm" bit
    south australia
    just got my parts today
    I noticed the water pump 16100 49846 says it is a pump.wtr2jzgte jza80
    i read on the ever reliable net that the 2jz water pump wasn't compatible with the 1jz.
    is this not the case and they are 100%interchangeable. also i have read a different part number every now and then. 1610049845 is there 2 different water pumps floating around?
    I gave toyota my chassis number so i assume it must be correct but i thought i might ask first.
    JZZ30 soarer by the way.
    i believe there is different water pumps depending on what car they came out of.. the water pump that went on my soarer 1j said 2jz-ge on the side of the box i think..
    od bod lookin thing that goes back down the block beside the engine.. has a pipe bolt in the back, and a pipe slide in with o-rings on top, and he thermostat housing go on the bottom..pointing out toward the ground/wheel
    AFAIK 2jz-ge don't fit 1jz-gte. 2jz-gte goes on 1jz-gte. Do a search on that as there is a heap of info. and I have never changed it personally.
    QUICKEST 1JZ'S IN OZ
  1. 1jz vs 2jz heads
  2. 1JZ into EA Falcon
    By bezza05 in forum Tech and Conversions
    Last Post: 27-01-2006, 10:18 PM
  3. Upgrading 1JZ alternator
    By beasht in forum Tech and Conversions
    Last Post: 19-01-2006, 08:28 PM
