Results 31 to 45 of 51
Thread: 2JZGE costs involved?
    Default Re: 2JZGE costs involved?
    If you really wanted a VVTI 2JZ-GE you could try these guys ? Its an ebay auction in the US for one. Have to check on what accesories comes wit it, ie loom and ecu
    http://cgi.ebay.com/ebaymotors/JDM-I...40159331QQrdZ1
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Quote Originally Posted by TheToyman75
    My 2JZ-GE cam with Auto, ecu, loom, airbox with complete intake, exhaust manifold and dump pipes, radiator, air con heat exchanger and pipes, JZZ30 bonnet hinges, washer bottle and charcoal canister. Bassically everything from inside the engine bay and even a set of JZZ30 wheels and tyres. I paid $900
    Can you get another one?
    Takai,
    I can only suggest keeping an eye out mate. The prices seem to vary quite allot but private sales seem to commonly be around that price give or take a few hundred $$$.
    You could see what CLG has at the moment ?
    Junior Member Backyard Mechanic Dimitri's Avatar
    why do you think you would need a motec to run a vvt 2j? its 1 cam. im not 100% familar with the system fitted to the 2j but i was under the impression it was a exhaust cam only and not constantly varying.. similar to a 20v. if this is the case i dont see the harm in having it rpm switched. the factory ecu takes into account a few more variables, but in practise (on a 20v) this doesnt seem to make much differance.
    2JZ is VVTi (as has been posted about 10000 times this thread) and not VVT.
    VVTi is as you guessed constantly variable, and only MoTeC and Autronic at this stage can control it.
    And its on the intake cam.
    sorry. i am wrong. could you run it switched anyway?
    AFAIK no, on the variable setup you either use it fully variable, or you don't use it at all.
    Could be wrong on this though.
  8. #38
    Rod: How did you end up wiring up the Auto? Did you use the A350 or sandwich an A340 on?
    sideshow: have you ever wired up an A340 alongside the 2JZGE Auto ECU?
  9. #39
    just found some news about the autos
    on a 1jz vvti the auto shifter has an ecu in it aswell
    this talks to the engine ecu and the auto gbox
    i will go over my 1jz vvti diagrams and see if theres a way around it
    but i dont think so at the moment
    so im not sure if the 2jz vvti is same as 1jz in the ecu workings department
  10. #40
    Takai,
    Mos did all the wiring for my old girl. The factory Auto came with the engine so is wired in complete with the Auto ECU check light, Power button and overdrive on/off switch Works a treat.
  11. #41
    4 speed or 5 speed ?
  12. #42
    not wired an a340
    what does the 2j have
    this 1j i will finish off this thursday
    a normal toyota auto is piss easy to do
    this is my first 1j vvti and the shifter has an ecu with it
    i have another one to do in afew weeks but the customer doesnt have the shifter for it
    so i have to see if theres a way to get around it
    the vvti ecu seams to have much more inputs than yr normal 1jz
  13. #43
    Only the 4 speed mate
    Just the normal run of the mill Toyota Auto I'm afraid.
  14. #44
    Damn, the JZZ31's must have gotten the 4 speed whereas the JZA80's got the 5 speed.
  15. #45
    My 2JZ-GE is from a 1994 JZZ30 mate.
  1. 2JZGE Waterpump onto a 1JZGTE...who has done it?
    Last Post: 11-03-2011, 06:32 PM
  2. 2JZGE into MX83
    By rvrolla in forum Tech and Conversions
    Last Post: 21-05-2007, 10:16 AM
