I would've thought the main killer would be a manual conversion.Originally Posted by CrUZida
im paying 1k for one, ecu/loom/exhuastOriginally Posted by takai
thats what i meant... i'll just pick up a non VVTi engine and be done with it. As for a 1JZGTE i've seen how ridiculous that is in a Z10 and i really don't wanna kill myself... 220hp odd should be a pretty big kick in the pants anyway in an 1100kg car... plus the insurance benifits would be good... 1UZ well i don't wanna go to an 8Originally Posted by JustCallMeFrank
MZ-10/GZ-10 hybrid turbo rolling shell, RB30 powered
IS200 - 1GFE
Oh, and I didn't make my last post clear.
It should have read,
If you decide to go for an aftermarket ecu and plan to use the VVTi, then you'll have to go with Autronic or MoTeC.
You can by all means stick with the factory ecu after you have solved the fuel delivery issues.
Surely you can get a non VVTi 2JZGE for less than $1000 in your part of the world?Originally Posted by CrUZida
As for VVTi, stick with factory fuelling and ECU. That said, you could probably get a 1UZ and assorted manual bits for less than a VVTi 2JZ....
By the time you factor in a 2JZ bellhousing, flywheel, and new clutch a manual 1UZ is not *that* much more expensive. Few hundred tops.Originally Posted by JustCallMeFrank
Hahah, you'd be lucky to pick up a 1JZ nonVVTi for less than a grand here.Originally Posted by gianttomato
nonVVTi 2JZ's with loom/ecu fetch $1500 minimum, unless you happen to snag some chump in a JZA80 who's just upgraded.
VVTi 2JZ with full loom/ecu would be estimated $2500.
I suppose, depends how cheaply you can get those, the price tends to vary depending on how lucky you get.
Insurance, engineering and the other usuals. The 2JZGE is counted as an "EFI Hardware Change" here in SA for some reason. They consider it the same as going from say a 253 carby to a 253 injected. No idea why, and i wont complain.Originally Posted by CrUZida
theres no probs with engine with no return line
i have done over 10 of them either holdens or fords
all u do is find the fuel pressure specs on the engine and fit a non rising rate malpasi
adjustable fuel pressure reg
u can fit it either in engine bay or near tank
no return line just means the return is built into the pump
theres nothin complicated about it
the biggest prob would be the auto
if u plan to run auto u might need the std 2jzvvti shifter
im wiring up a 1j vvti and the ecu talks to the gear shifter mechanism
so without that it might be a pain to get goin if the 2j is similar to the 1j
illhave all the info on how it works soon so ill let u kow if its a problem
With the 2JZGE non-VVTi i understand that the A350 is controlled by the engine ECU on the Autos. Im therefore guessing that it may have a bit of a confusion fit if it is mated up to a A341E with the external shift computer from the 7MGE.
Any ideas?
Go manual?Originally Posted by takai
Daily: DC2 Integra VTiR :: 96kw @7300rpm - 132nm @6300rpm
Techno Toymods | Beninca Dyno Day Results 10/9/05 | GOR Cruise '06 | My Photography and Illustration
doesnt a manual gbox for the 1j cost around 1500 to 2000
R154 would be that much, yes.
but if he goes manual for the 2jz-ge, would be less for the w58 (although if it's an auto to start with, all the associated hardware adds up)
My 2JZ-GE cam with Auto, ecu, loom, airbox with complete intake, exhaust manifold and dump pipes, radiator, air con heat exchanger and pipes, JZZ30 bonnet hinges, washer bottle and charcoal canister. Bassically everything from inside the engine bay and even a set of JZZ30 wheels and tyres. I paid $900Originally Posted by CrUZida
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
