Results 1 to 11 of 11
Thread: KE55 clutch adjustments
    Junior Member Grease Monkey pushrod_POWA's Avatar
    Default KE55 clutch adjustments
    Hey,
    I just put my 4k back in my car and now the clutch isnt working. My gregory's repair manual says that the e clip should be 5-6 groves away from the washer. That doesnt seem to work. I have tried moving the e clip forwad and back but that doesnt work either.
    I have also adjusted the pedal according to the specifications in my repair manual but that had no effect either. Now could this be something that I have not looked at yet? When I took the engine out I did not touch the other end of the clutch cable so I dont think it would be something there. Any suggestions on what it could be?
    Default Re: KE55 clutch adjustments
    when adjusting clutch cable at firewall.. pull the cable out as far as it will go, then put clip in maybe 1 spot back.
    are you sure neither end of the cable has come off/out? did you do anything to the clutch? is the clutch fork seated properly etc...
    I did that and stil no result,
    The other end of the cluch cable is stil on and I didnt even open the bellhousing so i doubt it would be something in there.
    Junior Member Backyard Mechanic Hokey's Avatar
    does the clutch fork even move when the clutch goes in? that will rule out internal problems
    yes it moves but only 2-3cm
    what is it doing if u start it? will it go into gear whilst idleing? or just crunch?
    crunch then stall.
    maybe the wire has been stretched then if you said you adjusted it to what it told you in the gregorys
    Yea maybe. I'll get my dad to look at it over the weekend. Well thanks for the help. pos rep comming your way
    Quote Originally Posted by pushrod_POWA
    Hey,
    forward with less grooves? or more grooves?
    if you pull it out as hard as you can, there should be little free play in the pedal..
    how much pedal free travel is there now before the cable takes up?
    I have tried it with all the groves in between the washer and the e-clip and have had it so there is no grooves between them.
    well atm there is no grooves between the washer and e-clip. there is about 1-2cm free play before the cable takes up.
  1. Clutch LSD => Torsen LSD
    Last Post: 21-10-2006, 03:14 PM
  2. W58 7M-GTE clutch choice
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 03-02-2006, 08:57 PM
  3. clutch for 4age blue top
    By Sigg. in forum Tech and Conversions
    Last Post: 21-01-2006, 12:19 AM
