Results 1 to 15 of 17
Thread: alternatives to a 2s for a rwd?
    Mar 2008
    westmere
    Default alternatives to a 2s for a rwd?
    i have been given a st141 corona ( conrod through the block ) to add to my group of toys and am trying to decide on an engine to drop into it. it had a 2s-c in it and has the borgwarner 5 speed, i have got my 3sgte sitting in the shed from my last project ( fwd rally celica ... crashed on a hill climb ) and it bolts up to the gear box fine. however i have decided against the std turbo ( due to the modifications required to make it clear the mount, face the right way etc. so i was curious or the other options ?
    so far i know i can use any of the 3s engines. i was even thinking about rebuilding the 2s using a stronger botom end ( 3sge ) and turboing it ??
    will a 5sfe block fit the box? and do they have both engine mounts on them ? do any of the 3s engines have holes in the block to allow for the two engine mounts?
    and one more thing any one know anything about the box ?
    T807-33-101
    0507-066 [T5699]
    Is all thats on the box.
    Default Re: alternatives to a 2s for a rwd?
    use the 3SGTE and just do whatever to make the turbo point the right way, make an exhaust manifild if need be.
    dont use a 5SFE or 2SC head unless you must be different.
    id be temp0ted to just stick a standard engine in it and drive it around, or go the whole deal and put in a 1JZGTE and R154 etc
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Mar 2008
    westmere
    i love being diffrent haha its not a daly driver, it is purley a car to use on local gravel climbs. hense id like to twaek the power a tad. i read some the 2.5 or 3 liter v6 may fit is this true ?
    Mar 2008
    westmere
    *and as for the 1jz ... i drive its big brother to work every day, i want to try something new
    Converting 3S-GTE to RWD is nowhere near as easy as it seems. Yes the bellhousing bolts up but that's the least of your problems. If you want a 2 litre turbo engine it's cheaper and easier to use something like an SR20.
    Montrose
    Bogwarmer box + turbo = good times...
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Quote Originally Posted by mrshin
    for 2.5 seconds
    Jun 2006
    There is a guy on here that has a VP Commodore V6 in one.. Cheap and plenty of torque.
    Junior Member Backyard Mechanic MOOKIE's Avatar
    tas
    thats what i was thinking a commo v6 would be perfect.
    Mar 2008
    westmere
    i heard or read somwhere the vz engies bolt up .... is this true ?
    Quote Originally Posted by xlr8_07
    VZ engines bolting up? I doubt it.
    What about a 3RZFE?.... then add a turbo. already a north-south engine for starters.
    Beams 3sge?
    1uzfe?
    1jzgte?
    1ggte?
    they all fit with some lovin.
    Nath #347 Backyard Mechanic PHOBIA's Avatar
    IJ or 1G....
    Cheap and easy enough (been done before) and will make plenty in standard trim.
    Or just sorce a 22R-E. Straight bolt in with upgraded fuel system for the EFI. Easy.
    1986 RT-142 Corona. Taking the phrase “WTF”, to a whole new level......
    PHOBIA. Fear of.........investing your soul into customizing a "f@#kin what" a Corona???
    Click to see PHOBIA
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Basically you can't go past a 1G-GTE in these things. Been done plenty of times so there is enough info to go around for you and can easily make enough power for hillclimbs.
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
  1. Alternatives to RT141 disks for T Series Diffs
    By chubbylover53 in forum Tech and Conversions
    Last Post: 14-01-2008, 07:02 PM
  2. stupid question out of curiosity.. 2s -twincam?
    By rke_011 in forum Tech and Conversions
    Last Post: 26-08-2007, 12:37 PM
  3. 2S -> 3S Conversion
    By 81rolla in forum Tech and Conversions
    Last Post: 22-02-2006, 01:08 PM
