Page 8 of 13 FirstFirst ... 678910 ... LastLast
Results 106 to 120 of 192
Thread: RA23/28 with KE70 steering column and rack and pinion
  1. #106
    Default Re: RA23/28 with KE70 steering column and rack and pinion
    Yeah, getting them to fit is the same. It's also worth mentioning to get the knuckle from the p/s rack as the shaft coming out of the rack is larger than the non p/s one.
  2. #107
    Nov 2010
    I'm so confused :S
  3. #108
    Quote Originally Posted by gmonkey View Post
    I'm so confused :S
    About what? If you've found a complete KE70 steering setup, get it, and fit it.
  4. #109
    Quote Originally Posted by Spectre View Post
    I don't think he has though.
    He has found a rack, and seperately found a crossmember from SamQ, but he still needs a complete steering column.
    ([][][]II--LT--II[][][])
  5. #110
    the one off a corona is also compatiable, I might be able to get one of them this weekend
  6. #111
    If you want to get the steering column made up without having to hack and slash it, I have a guy who setups it up with a unique little carrier bearing, and it's better than new.
    Facebook | LinkedIn
  7. #112
    Nov 2010
    ok ok so i still need the corona or ke70 steering column ?upper and bottom shafts? and also what intermidiate shaft do i need? And you guys recommend i get the ae86 PS knuckles for my non PS rack?
    Am i correct or still lost?
  8. #113
    Don't worry about the AE86 powersteering knuckles. Just use your standard ones, unless you really want the extra lock...
    You need the bottom of the KE70 steering shaft, to weld to the bottom of your celica shaft. You'll want to grab the KE70 shaft that joins the lower KE70 knuckle, to the KE70 rack knuckle.
  9. #114
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    if ke70 knuckles are the same length as ta ones i would highly recommend power knuckles if you can get them as it will have a large turning circle without. for example i couldnt get close to doing a u in a 2 lane street but with the power knuckles no probs with the extra lock.
    cheers mat
  10. #115
    If you can find AE86 p/s knuckles grab them. But they are rather hard to find, lots of people want them, and you'll pay for them...
  11. #116
    Nov 2010
    found some on ebay
    just bought em
    theres another set still on there bit more$$ but
  12. #117
    The P/S knuckles can still be bought new from Toyota last I heard, for cheaper than most people sell the used ones for also.
    I think Takai was the one with the info on that.
  13. #118
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    I got a set new from amayama in japan (forum sponsor) - cheaper than the local dealers could do, and much cheaper than second hand - worth a look.
    1976 RA23 Celica - 3SGE Blacktop Beams Powered!
    1994 KZN130 Surf - Daily 3ltr Turbo Diesel Goodness!
  14. #119
    Just FWIW - I wouldn't go welding the base of the KE70 steering column to the RA23 steering column.
    My experience is this doesn't end well.
    The solution I found is what I mentioned above - well worth the investment.
    Facebook | LinkedIn
  15. #120
    The old One Backyard Mechanic
    Quote Originally Posted by Major Clod View Post
    Do you happen to have the part number to make it easier on amayama?
    CHeers Craig
  1. TA22 + rack and pinion
    By "Z" UTE in forum Tech and Conversions
    Last Post: 19-05-2017, 12:02 PM
  2. AE86 "Cusco" quick steering racks??
    Last Post: 02-06-2007, 01:13 AM
